Alpine Aqua cooling system
- Been thanked: 430 times
Hi almal
Nie seker hoe effektief hierdie sisteem is nie, maar hy het saam met my Patrol gekom en ek gaan n front mount intercooler op sit terwyl ek besig is met die engine so gaan nie die bad boy nodig he nie.
Dit is die cooler, sy "radiator" en die waterpompie met al die pype. Daar was n extra fan op my aircondensor gewees so eks nie seker of dit deel was van die sisteem of nie.
Ek het nie n idee of dit iets werd is nie so sal dit pretty much weg gee of ruil vir enigiets wat ek dalk kan gebruik op my Patrol.
O ja dit is vir n TD42 engine.
- 20140312_183845-1900.jpg (173.77 KiB) Viewed 2857 times
- Been thanked: 473 times
Re: Alpine Aqua cooling system
Is this not a water to air intercooler.... I would really like to do this conversion as I believe that for a top mount IC there is soooooooo much heat soak that the water to air will probably be the best way of dealing with that.
What would you want for it? I might be able to get it up here to JHB from Richards bay via my better halfs company.
Hmmmmm.... just looking at it now carefully..... is that not maybe for a watercooled turbo. I can't see if that fitts an intercooler or turbo. If you are keeping the same turbo, then I think you will need this....
ricster, I think this acts as an intercooler but works slightly different.
Ill post another photo of the "Intercooler". It basically connects in between the turbo and the intake and then has water that runs around it and cools it down. The small "radiator" sits in front of the engine radiator and its got a water pump that circulates the water through it.
In short, its basically a normal intercooler inside a box with water flowing around it.
Oh and I live in Centurion, PTA. Richards Bay is just my home town.
- 20140312_183421-1900.jpg (122.27 KiB) Viewed 2833 times
Brilliant.... Lets talk turkey.... you said " Ek het nie n idee of dit iets werd is nie so sal dit pretty much weg gee of ruil vir enigiets wat ek dalk kan gebruik op my Patrol".... well I have an old TD42 piston with a hole in it.... a TD42 head with a crack in it ( will make a fantastic door stop in a hurricane)..... well used aluminium side steps.... and lots of empty 5L oil containers.... so I'll have to give you some money....
Ha Ha Ha ok, well make me an offer.... I really don't know what its worth. R1000 to much?
My wish list is as follows
1.Roofrack (you can pay in the cash difference) just kidding
2. spare wheel cover
3. left front indicator, mine is cracked
Whats the condition like, basically regarding leaks ? I hear that is the main issue.
I have tested it to see if it leaks between the water and the air side and all seems well in that department. The water pump also works 100%
I would like to take it off your hands.... I'll PM you
I might just have a new 33" sparewheel canvas cover in my garage.... will have to hunt it down though....
Sold!!
