Fan blower makes screeching sound
- Full Name: Florian M.
- Nickname: Flo
- Home Town: Hoedspruit
- Current 4x4: '99 GRX 4500
- Home Language: German
- Has thanked: 42 times
- Been thanked: 34 times
Hi folks!
My fan blower sometimes makes screeching sounds. It mostly occurs after it ran for a while in high outside temperatures.
I did already unscrew the motor/ fan blower unit and clean the fan blower. This help only for a short time.
Do you have an idea what i might try to re-lubricate / clean or alter?
A new motor 27220VB002 is quite expensive in Germany - does anybody know a parts dealer who might sell it in SA?
That would be just as a last solution, I'd rather like to solve it by myself by other means - if somebody has an idea what might cause the noise.
Thanks for you inputs!
Florian
Florian
- Been thanked: 1036 times
Re: Fan blower makes screeching sound
Florian, it is probably the fan motor's bushes or bearings.
I am not sure if they can be serviced, you will have to remove the fan motor again and see if you can get it apart without damage (be carefull of the brushes, particularly when re-assembling).
Alternatively you may have to look for a second-hand unit, or try Nikolai at euro 4x4. He is a forum member here, so you can drop him a PM.
- Nickname: Flo
Hi Peter,
thanks for the reply. That is what i feared. I didn't want to open up the motor when I had it out the first time, maybe I'll try again.
Thanks for the contact to Nikolai!
Florian
Florian
- tour de frans
- Been thanked: 22 times
The fan motor on my patrol is starting to do the same. The noice are ony there when the dash is on re-circle. Anyway I did took a peek at the motor assembly and it look pretty std.
What I mean, a Ford ranger uses the same. I will investigate and update.
Rdgs
Frans
Rdgs
Frans
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
- Nickname: Flo
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 27 times
- Been thanked: 136 times
On my '98 model there's no "pollen filter"". so the fan sucks in a lot of gunk when you go off-road. This stuff collects on the fan blades, builds up and eventually scrapes against the fan housing (sccrreeeEEEECHHH!!!). By this time the fan also vibrates when running at high speed, as the extra weight unbalances it.
I removed the cubby lid, opened the fan housing, removed the motor & fan assembly and cleaned it thoroughly (the fan blades, not the motor bearings). This did the trick on mine - you may also be lucky...
- Been thanked: 473 times
Chuck has a pollen filter???.... Where did you get that?.... have you got any pics?
Oefffffffffff - lae hou meneer ref
Cedric -- blonde moemnt there -- Slangaman says because Chuck does NOT have a pollen filter he had to strip it to clean it
Graham does a mod on the 4.5 so that you can add a filter....he cuts a hole somewere and slides one in mabe we must get him to post some pics?
- Full Name: Andries
- Nickname: None
- Home Town: Pretoorsdorp
- Has thanked: 28 times
- Been thanked: 38 times
The pollen filter conversion is well documented on the Oz forum. Any ideas what they cost though?
