5 x 265/75R16 (32") Kumho KL71 on VW 16" steel rims
- Full Name: Theunis Kruger
- Nickname: Theunis
- Current 4x4: Amarok 132kW Auto 4Mo
- Has thanked: 1 time
- Been thanked: 7 times
Hello all
These were used as a second set on the Amarok and they work pretty dam good through my experience and online reviews as well. Minimal use as per pictures (app 2mm used). No plugs or repairs. These are in excellent condition.
They fit the Amarok perfectly, but the RHF would rub against frame at full lock to the right. Clears everything else.
Price for 5 x tyres, 6 x VW OEM steel rims and 4 VW centre caps is R10'000. Split is R9000 for tyresand R1000 for rims.
Reach me on Zero ate too 77 too too five 17
- Tyre & Rim.jpg (115.54 KiB) Viewed 2366 times
- Cap.jpg (127.64 KiB) Viewed 2366 times
- Has thanked: 60 times
- Been thanked: 255 times
Re: 5 x 265/75R16 (32") Kumho KL71 on VW 16" steel rims
Hi Theunis
Do you knwow if these rimms fit the Patrol?
And if not, would you sell the rubber without the rims?
- Full Name: andre durand
- Nickname: leeuloop
- Home Town: Alberton
- Current 4x4: PATHFINDER
- Home Language: afr
- Been thanked: 37 times
Hi CEDRIC kan die selfde KUMO,S kry vir R 2000 per tyre by LOMBAARD TYRES
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
Theunis - doen n toets of daai 5-gat rimme op n X5 BMW sal pas -- dan kan jy vinnig die wiele verkoop -- die BMW X5 manne wil ook af die pad gaan - maar met daai snotskep wielietjies wat BM mee uitkom is hulle gefnuik.
- Nickname: Theunis
Hi Alex
I doubt it; the VW rims have a PCD of 120mm, while the Patrol's is 139.7mm (according to Google). As per the ad I am happy to sell them separately as well; let me know via PM or ring me if you are still interested.
Dankie Andre; dis waar ek hulle ook gekoop het en vir die bande alleen is dit R1800 per band. Vir party mense is dit genoeg van 'n verskil.
Oompie Mac, sover ek kan sien is die minimum grootte vir die X5'e 17", so hierdie 16's sal nie werk nie. Dankie vir die voorstel!
daai BM eienaar moet net ,6 mm afskuur met sy angry grinder - dan pas die 16 duim rims op hom en daar is geen verswakking van sy remvermoe nie -- Kyk maar hoe Ewald sy Safari se nuwe rims maak pas het .. kleinnn bikki angry grinder en WALLA - dit werk
kyk hier op ons F B Groep :
- Nickname: Theunis
Oompie Mac,
jy neem aan meeste ouens wat BMW's ry weet hoe werk 'n angry grinder...???
Nee Theuns -- die meeste weet dit NIE -- MAAR daai een of twee wat wel wil gaan bergklim met sy X5 en weet dat hy minder rim en meer tire noorag het .. hulle sal weet.
Die ander juppies sal altyd juppies wees - noudiedag een gehad. Se bril se armpie se kroefie kom los. Ek gee hom my kleinnnn bril skroewedraaiertjie -- en hy WEET NIE HOE OM DIE SKROEWEDRAAIER TE GENRUIK NIE..
[ek het skoon klere noorag gehad na daai een ...]
- Nickname: Theunis
- Nickname: Theunis
