Electronic Ignition
christolemmer
Junior Member
Junior Member
Full Name: Christo lemmer
Nickname: Christo
Home Town: Menlyn Pretoria
Current 4x4: Nissan Patrol 4.5 gl
Has thanked: 10 times
Electronic Ignition
Post by christolemmer »
I own a 1996 Patrol 4.2 SGL. I would like to know if it is advisable to change the points and condenser to electronic. Will such a conversion have any affect on power and feul consumtion?
firessafari
Full Name: Johan van Vuuren
Nickname: Johan
Current 4x4: Safari s/w
Been thanked: 7 times
Re: Electronic Ignition
Post by firessafari »
Hallo Christo,
Welkom hier by ons. Jy moet eerste 'n foto van jou Patrol plaas anders gaan Oompie Mac jou gryp
Om jou vraag te andwoord. Ja dit is voordelig in die sin dat jy nooit weer die tyd hoof te stel nie want daar is nie punte wat wegwerk of brand nie
Baie vervaardigers beweer dat dit jou voertuig meer krag gee en die brandstof verbruik verbeter maar dit het ek nog nooit ondervind nie ek dink dit is maar meer 'n verkoop slenter.
Johan
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
This is one of the best upgrades you can do to a car with standard points and condensor.
Fit a Pertronix Ignitor and never worry about timing again and your car will start easier and idle smoother :thumbup:
On my old Safari I also replaced the coil to a Flame-Thrower Coil with new leads and new distributor cap.
Rudolph
Nickname: Rudolph
Home Town: Port Alfred
Has thanked: 107 times
Been thanked: 36 times
Post by Rudolph »
Agree, this is a very good mod to do, just keep your points and things you take out in the tool box just for incase you need them in the bush one day... QQQ Have also done the mod and it works perfect. Contact Offshore Marine International, 021 786 1007, omiintl@mweb.co.za. it will set you back at about R1100.
christolemmer
Junior Member
Junior Member
Nickname: Christo
Baie dankie vir julle raad. Ek wou altyd die Patrol standaard gehou het maar die " Slet " se punte moet gereeld gestel en skoon gemaak word.Gaan dit nodig wees om die coil en plugs ook te verander? Kan n mens die carb wat n alt. compensator op het so verander dat dit sonder die compensator kan werk? Ek sit n foto op sodra ek weet hoe.
firessafari
Nickname: Johan
Christo
Moet nie reg maak wat nie stukkend is nie los die compensator net so, installeer die electronic ignition volgens die vervaardiger se instruksies noukeurig ,dit is nie nodig om plugs te vervang as die oues nog goed is nie. maak net seker die elektrode gaping is nog reg.
Johan
christolemmer
Junior Member
Junior Member
Nickname: Christo
Johan
Dankie ek dink jy is reg. Die carb het nog nie gepla nie. Weet jy van ouens in ons omgewing wat die Patrol ordentlik kan instel sodra ek die ignition vervang het?
Groete Christo
firessafari
Nickname: Johan
Christo
Nee ongelukkig nie,Ek woon in Krugersdorp ,Maar komtak oom Mac , PM(personal message )hom , Hy is op hierdie forum KAGISO 11 ek is seker hy kan jou help
Johan
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Post by SCUBA Patrol »
Removed
Phillip
2006 3l with MADMAN
Has thanked: 189 times
Been thanked: 270 times
christolemmer wrote:Johan
Groete Christo
Vat hom na Graham cummings 9Pathmaker) toe hy is in Valhalla en werk om 'n hele paar forum Patrols.
