ZD 30 Boost Control Fundi Needed
Tony
Full Name: Antonio Barone
Nickname: Tony
Home Town: Greyton - W/Cape
Been thanked: 40 times
Post by Tony »
Trying to eliminate overboost and getting hopelessly confused!! Managed to fiddle with the VNT thimmajig and looks like I have gone and lost my original setting. I am seeing very short boost pressures of up to 1.0 1.2 and 1.3 bar when accelerating, and when on the flat at +-2500 rpm right down to 0.4 - 0.6 bar, which is great considering that it was up to 1.3 bar when cruising all the time. However, she does'nt have any go when I put foot to pass. Takes a long time to build up speed. Does anyone know how to set up properly ??
Re: ZD 30 Boost Control Fundi Needed
Tony have you tried the manual ? The jappies with the thick glasses normally knows best ??also look on the aus forum they have a lot of info on the 30l there :mytwocents:
Bekker
Full Name: Bekker van Niekerk
Nickname: Bekker
Home Town: Wellington Westren Cape
Current 4x4: None
Post by Bekker »
Hi Tony
I can refer you to the Nissan Patrol Reference Document by AKSNISS
www.patrol4x4.com/forum/Version:2.4
Bekker
Bekker van Niekerk
0828017117
bekker@paarlrek.co.za
Tony
Nickname: Tony
Post by Tony »
Thanks for all the info guys, but I was really wanting to know whether any of you have fiddled with this setting, and what the effect was by turning clockwise versus anticlockwise, also if there is any detrimental effect should the setting not be done correctly. Also, what boost pressures would be normal and what would be the maximum allowed - measured in bar.
I do have a manual for you with extra info for the 3.0d engine and I'm in Kempton Park.
Tony
Nickname: Tony
Post by Tony »
Dankie Herrie, I made contact with Graham today, and will pay him a visit next week and he will go through the setting with me so I can sort out this issue myself next time without causing too much k**k!!
Thank you for the offer - good to know for future refference, cheers mate.
