4.8GRX Autobox problem - Clueless????
neilraulstone
Junior Member
Junior Member
Full Name: Neil Raulstone
Nickname: neil
Home Town: Ermelo
Current 4x4: Patrol 4.8 GRx
Home Language: english/afrikaans
Post by neilraulstone »
Hi , I have a 2004 Patrol 4.8 GRX with auto transmission, a few months ago I started the patrol and reversed as normal, and when I engaged Drive, the at light flashed on the dash,I pulled away and the vehicle was stuck in 3rd or 4th and could almost not get going. Took it to the dealer, Foult code was" Lower coast brake solenoid circuit", so they replaced my entire valve bank. Got the Patrol back and after one week it did exactly the same,after diagnostics they checked all the connectors and harness to tcm where after they cleared all faults and reprogrammed the G/box. Drove the Patrol 5 days and it is doing exactly the same, The dealer doesn't know what the couse can be(mechanical or electrical)..... has anyone maybe had the same type of problem....
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: 4.8GRX Autobox problem - Clueless????
Post by AndriesS »
neil, the only suggestion i have is to work through the workshop manual yourself and do some of the tests- I'm not sure what type of specialised equipment you will need and how technical you are - from your business it does sound that you are technical . You might PM Graham Cummins, Dennis or Tour de France on some ideas as they have a very good technical knowledge of the vehicles.
firessafari
Full Name: Johan van Vuuren
Nickname: Johan
Current 4x4: Safari s/w
Been thanked: 7 times
Post by firessafari »
Eina that sounds like Money. The oil level is ok i presume and the filter is clean.
Speak to the guys at maifair gearbox they do all the gearboxes for nissan at least they can do tests ect and not just reaplace everything ..... :mytwocents:
neilraulstone
Junior Member
Junior Member
Nickname: neil
Home Town: Ermelo
Thanks guys for the feedback, we are busy working thru the workshop manual to see if we can find something.I presume that the oil levels are correct and that the filter is clean as they did replace the entire valvebank...will do follow-up with nissan. I will keep you posted if we resolve this problem.....
I don't know. The history but that box is serpose to have nissan I think tipe N oil in ?????mabe someone put the wrong. Stuff??????
neilraulstone
Junior Member
Junior Member
Nickname: neil
Home Town: Ermelo
I had to buy the special spec oil From nissan so I presume that it was put in....Rex Gearbox and Diff did the G/box, They are also looking for a possible solution... :think:
neilraulstone
Junior Member
Junior Member
Nickname: neil
Home Town: Ermelo
At last..Light at the end of the tunnel.... :blonde: Had an auto electician do some tests, he found a fault(Worn wire) in the main harness leading from the Gbox to the computer witch caused the Gbox to go into limp mode. It's been 3 weeks without any problems. :woo: Now im ready for my Malawi/Pemba tour in June......6500km Return trip of witch 900km are totaly offroad :rolling:
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Post by Stefan »
Glad to hear you got it sorted out.
NISMOnator
Full Name: Jacques Strauss
Nickname: NISMOnator
Has thanked: 19 times
Post by NISMOnator »
Happy Patrolling! :blonde:
