Stats.
- Reinier Claasen
- Full Name: Reinier Claassen
- Nickname: Gwantas
- Home Town: Ballito
- Current 4x4: 2000 Nissan Patrol 4.5GRX
Stats.
Where can one get the stats for the patrols? I'm looking for things like Kw, torque, approach - breakover - and departure angles, ground clearance, wading depth etc. for a 2000 4.5grx?
Re: Stats.
i think the angels are the same as the 4.8 it is the same car different motor did you look at the test on 60th model ?wading is about 700mm but i stand corrected
Re: Stats.
The SA4x4 of January have the test of the 4.8 Adventurer 60 and the only difference is the engine stats.
- Been thanked: 1038 times
Re: Stats.
Google "specs". There is a download on Nissan SA website somewhere.
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 29 times
- Been thanked: 136 times
Re: Stats.
Excerpts from a Patrol brochure that you can download from Nissan's website:
Approach, departure, ramp angles (degrees) 37, 31, 27
Max tilt angle (degrees) 48
Max gradient (degrees) 39
Max wading depth (mm) 700
Minimum ground clearance (mm) 215
But.... the Madman EMT sensor in my Patrol indicates that I did a 40 deg gradient in mine, so the limits are not necessarily cast in stone
- Reinier Claasen
- Nickname: Gwantas
Re: Stats.
I also use this sit but the oldest they have is the 4.8 2002.dieselfan wrote:http://www.um.co.za/specifications/nissan.aspx
Thanks guys.
- Gerrie
- Full Name: Gerrie van Eeden
- Nickname: Gerrie
- Home Town: Cape Town
- Current 4x4: Igor a 1989 Toyota Hilux.
- Been thanked: 1 time
Re: Stats.
For Departure angles and breakover, approach, take a picture of your Patrol from the side - straight on, take out the old gradeboog (no idea what it is called in English) and draw lines to measure the angles...
Re: Stats.
Reinier, I am sure the ramp and departure ass well as rollover/sideslope and fording depth will be identical and the approach will be the same or maybe slightly better.
This all assumes standard suspension and standard tire sizes, off course.
- Full Name: JG Shields
- Nickname: JG
Re: Stats.
Reinier,
Ek het vir jou 'n PM gestuur. Ek het 'n artikel met die volledige specs van die 4.5GRX. Ek sal dit graag vir jou stuur.
Patrol fan!
