Hi Guys,
I have a smell diesel leak on my diesel pump. It seems to be coming from the back of the pump. Is this a diy job or should I look at sending it in for a repair. Anyone you can recommend in the northerns suburbs? Cheers Adrian
Diesel Pump
- tour de frans
- Been thanked: 22 times
Re: Diesel Pump
Hello, Check on back if one off the pipes is not leaking. Or in the middle between the injector pipes there sit a plug , 12mm socket. Check if that is tight.
I would guess a pipe.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
- Full Name: Adrian
- Nickname: Adrian
- Current 4x4: '91 SWB Patrol 4.2d
- Been thanked: 1 time
Re: Diesel Pump
Hi Frans, the leak is coming from around the plug between the injectors. The M12 bolt is tight. Is there a seal of sorts that I can replace?
- tour de frans
Re: Diesel Pump
Hi, sorry for the late reply. If you pull the bolt out there should be a copper washer.
You can crack the bolt loose and tight again to see if it would seal. But pull the bolt and fit a new washer,that is only a plug on the back of the pump.
- Full Name: Adrian
- Nickname: Adrian
Re: Diesel Pump
Thanks Frans, turns out it was one of the seals on the body of the pump that was leaking. I got Randburg Diesel and Turbo in Strydom Park (Bosch Agent) to service the pump for me over the christmas break. They really offer a good service. Unbelievably the vehicle sounds totally different after they have worked on the vehicle. The engine now has a deep addictive growl that was never there before.
- tour de frans
Re: Diesel Pump
Good stuff, Glad you came right.
