OME shocks - SOLD
- Full Name: Andries
- Nickname: None
- Home Town: Pretoorsdorp
- Has thanked: 28 times
- Been thanked: 38 times
OME shocks - SOLD
I have a front and rear set of OME shocks for the GU /Y61.
Some history
I bought it from a forum member who left the country who had it fitted for 8 months. It was fitted on his vehicle as part of a 2inch lift kit
It was then fitted to my vehicle for 13 months and removed due a communication failure when I upgraded my coils.
The fitment center scratched them slightly during removal and did not return the rubbers, washers and nuts on the front shocks. I checked the standard nissan shocks rubbers, washers and nuts should fit.
Any reasonable offers will be considered
Some history
Re: OME shocks
How do I check if my shocks are still ok or not??.... cause I have a 2"lift OME lift (thought it was 3" lift but realised when parked next to Chuck Norris..... I'm a little shorter..
- Has thanked: 1134 times
- Been thanked: 1046 times
Re: OME shocks
Easy way: Jump on a corner, and see how quickly it stops. It must go down and back up, not continue going up and down.
Best way: Remove shock, and stroke it through it's entire range both ways as quickly as you can. It must give consistent friction. If it has spots where it suddenly goes soft, it is tired.
Re: OME shocks
I tried jumping on the corner once before..... nearly killed myself..
... foot hooked on the bull bar when I did my graceful jump..... which turned out to not be that graceful....
- davejones
- Full Name: David Jones
- Nickname: David
- Home Town: Lagos, Nigeria
- Been thanked: 6 times
Re: OME shocks
ricster wrote:I tried jumping on the corner once before..... nearly killed myself..... foot hooked on the bull bar when I did my graceful jump..... which turned out to not be that graceful....
so random but unbelievably funny!!
An ox, but with balls !!!
Re: OME shocks
hey what can I say.... I'm so unlucky that if Charlize Theron had triplets, I'd be the one that's bottle fed.....
- Full Name: michele Bertolani
- Nickname: mike
- Home Town: jhb
- Current 4x4: Nissan Patrol 4.2D 1998
- Home Language: english
Re: OME shocks
Hi would these shocks be suitable for a 2" lift, I intend to replace the total standard suspension soon however I would like to do the lift at the same time.
T
T
