First Post!
- Junior Member
- Full Name: Riaan Annandale
- Nickname: Riaan
- Home Town: Sandton
- Current 4x4: '99 GL 4.2D
First Post!
Hi guys,
I signed up a couple of weeks ago, but only got round to making a post now.
I've recently acquired - after looking for ages - a 4.2 Patrol station wagon - 1999 model and I'm loving it! Looking forward to lots of happy 4x4ing with the cabby!
Cheers!
Here's the template magody with my details in:
1. Name: Riaan
2. Birthday and Age: 10 July 1980 (so that makes me 31 at time of posting)
3. Town and Country of residence: Fourways - Sef Africa
4. Home Language: English
5. Occupation/Business: Data Architect - Telecoms/Internet
6. Family status: Married + one lightie
7. Membership - Other 4X4 Clubs and Forums: No other membership, but have had a tone of nissans so have always been involved with the likes of the 200SX owners club and the nizmo club
8. Current 4x4: Patrol 4x4
9. Current Mods: None
10. Mods on wish list: Suspension lift, drawer system, dual battery system, fridge, roof tent
11. Vehicle on wish list: None
12. Previous 4x4's: Can't really call it a 4x4, but I have an outlander too which my wife drives now
13. Last 3 offroad or overland destinations: N/A
15. Other hobbies: Golf and track riding (I have a 2008 Honda Fireblade)
16. GPSr and Map Data used: N/A
17. Rate your 4X4 and overlanding experience: Novice
18. Online Photo Site:
Cheers!
1. Name: Riaan
- Has thanked: 1135 times
- Been thanked: 1046 times
Re: First Post!
Welcome Riaan
This new Trollie of yours, I assume it is a Diesel? Is it normally aspirated or turbo'd?
- Junior Member
- Nickname: Riaan
Re: First Post!
Normally aspirated.
It's also done just over 400k. And still starts first time every time, no smoke at all :)
I looked for a while, and this was probably the one in the best nick.
Only issue I see, is it looks like the gearbox oil is leaking (from the drain plug even...
) so i still need to change oil and fix that. But need the right tools and the correct oil - local midas didn't have stock.
Re: First Post!
Riaan do you mean the drain plug on the gearbox, or the one in the bellhousing?
If it is the one on the gearbox, make sure the breather is not blocked?
- Junior Member
- Nickname: Riaan
Re: First Post!
Erm... Not sure - it's the plug that you see in the service manual? Kinda looks like you put a pretty big alan key in there.
I'm not very mechanically minded - so if you know of any decent patrol mechs in the fourways/randburg area, please pass along some details
Re: First Post!
Riaan this is a Manual gearbox hey?
That sounds like the gearbox drain plug. You use a 1/2"square drive as found on a socket driver (whether strongarm, t-bar or ratchet) directly. If you decide to look at it yourself, the filler plug looks similar but is mounted about 1/2 way up the side of the gearbox above the drain plug. You start by draining the oil. The drain plug should have a magnet on it, that should collect any pieces of steel. If you find shavings, don't worry, that is pretty normal, but if you find chunks you have a problem. Clean the drain and filler plugs. Refit the drain plug with Locktite otherwise it will leak a bit. Then fill the gearbox with new oil until oil starts running out of the filler hole, then you know the level is right. Use loctite on the filler plug as well.
The breather is a small pipe going in to the top of the gearbox, and leads to a higher place so that it doesn't swallow water on deep crossings. On my car it goes into the wheelarch.
Try Graham Cumming, he is near Swartkop AFB. 083 417 7503 or 012 651 3447. If you want to replace the gearbox oil, I recomend you ask him to put in Castrol BOT130M. It is not the cheapest oil on the market, but really works in the 'trol.
Re: First Post!
Baie welkom Riaan! I got the Patrol sticker for you and the manual on a cd if you need it.
Will you join us on the Patrol 60th Birthday?
Users browsing this forum: Semrush [Bot] and 2 guests
