Panhard movement
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Panhard movement
Post by AndriesS »
How much movement in the panhard bushes is too much?
I had a look underneath the car while the misses was turning the wheel and although there was no visible movement I detected some by pushing my finger between the rod and the plate next to the bushes bolt and then felt the rod would pinch my finger . Would that be to much movement then?
I realize that it could be dangerous and did not stick my finger all the way in, only enough to feel movement.
tour de frans
Been thanked: 22 times
Re: Panhard movement
Post by tour de frans »
Hey Johndough,It has to move,its rubber,but it must not fall arround.
If you can see a gap to the one side off the bush,when the oppisite is under pressure,thats to much play.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
AndriesS
Full Name: Andries
Nickname: None
Post by AndriesS »
Thanks, I'll go and check again, it think there might be a small gap.
