Diff gears
Witbobbejaan
Full Name: Dion
Nickname: D.
Home Town: I dont know, name keeps changing...Eastern Cape
Current 4x4: TB45
(Wife's TB42)
Has thanked: 34 times
Been thanked: 16 times
Diff gears
Post by Witbobbejaan »
Good evening Patrol Gurus...hope everyone is doing something on their cars or planning a trip!!
Question: Which models have hypoid gears in the differentials?
Thanks,
D.
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Re: Diff gears
Post by mvcoller »
All modern vehicle diffs have hypoid gears....
Witbobbejaan
Full Name: Dion
Nickname: D.
Current 4x4: TB45
(Wife's TB42)
Re: Diff gears
Great, thanks!
So presumably any transaxle oil will be compatible? some state hypoid, others not,so I always wonder...
Are there any other parts of the drivetrain with hypoid gears?
Has thanked: 244 times
Re: Diff gears
Correct diff oil would be: epx api gl5 80w90 :mytwocents:
mvcoller
Nickname: mvcoller
1998 4.5 Patrol SGL
Re: Diff gears
Post by mvcoller »
Witbobbejaan wrote: 20 Sep 2023 17:25
noun: hypoid gear
a bevel wheel with teeth engaging with a spiral pinion mounted at right angles to the wheel's axis, used to connect non-intersecting shafts in vehicle transmissions and other mechanisms.
Other than maybe on some 4x4 vehicles with portal axles, I know of nothing else that does, off hand
These gears generate extreme pressure on their teeth surfaces, hence the need for EP (Extreme Pressure) oil.
Has thanked: 1134 times
Been thanked: 1044 times
Re: Diff gears
SJC wrote: 20 Sep 2023 19:31 Correct diff oil would be: epx api gl5 80w90 :mytwocents:
Note that the "EPX" stands for extreme pressure.
This is specifically for hypoid gears.
Thus EPX and Hypoid are sinonyms in terms of the oil.
