29 March - 09 April 2018 Botswana Explorer's Route
Has thanked: 60 times
Been thanked: 255 times
Re: 29 March - 09 April 2018 Botswana Explorer's Route
Hi Chris
There were two 4.8 autos there.
One pre-face lift 2004/2005 (Tommie) and a face lift 2006 (Philip).
They were among the few that had virtually no issues.
Except that their break pads were also kaput. But that seems to be par-for-course on that terrain.
The clutch issues is a matter of age, and whether the clutch had been replaced before and properly sealed afterwards or not - to avoid that "grinding paste" from getting in.
The newer cars (referring to the two 4.8s) most likely had not replaced their clutches before yet.
Aex
Hulle het nie clutches nie. Hulle het torque converters...
Thus, any auto would be immune to that particular problem. The problem auto's have instead is overheating the transfer case oil while working hard, typically in thick sand.
But the Patrol is pretty good in this respect.
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Is al die voertuie wat clutch probleme ondervind het GQ's? Met ander woorde ouer as 20 jaar+...?
Been thanked: 430 times
Cedric, yes its weird but there is a small difference between working the engine hard and driving normal.
Worst I got on the trip was when I towed Alex and for that stretch I got around 4km/l and it was low range 2nd gear most of the time.
Fanus, nee ek dink nie dis hoofsaaklik n GQ, GU of ouderdom ding nie. Daar was plek waar die modder in kon kom by die clutch en dis wat die marakas gemaak het. Daar was ook n GU wat se clutch gegaan het.
Michael wrote: 17 Apr 2018 20:49 Cedric, yes its weird but there is a small difference between working the engine hard and driving normal.
Ja ek dink Michael en David se karre is min of meer dieselfde ouderdom as die GU wat ook clutch probleme gegee het, ook ongeveer 20 jaar.
But on the other hand, both the cars that eventually had to be recovered due to clutch issues had pretty high mileages on those clutches...
Cedric, the manual petrol cars often also show little difference in fuel consumption under tough conditions. I know we start at a 30% (wishful thinking) disadvantage, but my own consumption in sand, and even towing a trailer, is often better than my consumption in town, as long as I behave myself...
On the Auto cars this is most definitely not true though. And I am convinced shifting them to low range as soon as you see you are staying in the lower three ratios helps somewhat.
Some random non-4x4 photos.
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
Brilliant foto's
Thx Peter
Dankie Errol
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Been thanked: 202 times
Post by Anthony Forgey »
Hey Peter,... you are a gifted photographer... somehow you find beauty in the most ordinary things... very good pics :salute:
