low range gears
Re: low range gears
Just to keep everything in the same place:
I recently managed to acquire a transfer case in which somebody had fitted a set of Marks 2.86:1 low range gears (let's not go into what it cost, and just say both Dawid's cars are now considerably heavier). My brother and I fitted it last week and the first outing with the new gears was Hennops yesterday.
For starters, I can say that it makes a HUGE difference. It feels like I have much more time to make decisions and manuevre in an obstacle and engine braking on downhills is much better.
The most telling though is that second-last obstacle, the steep climb one climbs when turning left just before the big mud-hole. Previously, the slowest I could get up here was about 5km/h (1200rpm in first low). I needed to lock everything up to do this and there was a fair amount of bouncing happening.
I have plenty of photos of Patrols coming up there one two or even just one wheel to prove that I am not alone.
Now, I crawl up at just about idle speed (600-800rpm, or about 2.0km/h), and even managed it once with the rear diff open. No bouncing, no nerves, just an easy climb.
The point is, because I was going slow enough to keep all four tires in firm contact with the terrain, I needed far less momentum. This is exactly what I was hoping for, and I hope it also translates as such on Koos se klip...
I also had a dice with Tijmen. First gear, low range, as slow as possible but without touching the clutch. Result: Tijmen took 30 seconds to cover the distance, I took 1minute and 12 seconds. Of course, there are several contributing factors. He has 35" wheels, my current wheels are probably no bigger than 30". Also, I think his idle speed is set higher, and lastly I was holding mine back with some gentle braking, going down to around 500rpm...
Of course, this is not conclusive proof that 2.86 is the ratio to get if one has the choice. It will be a good long while before I can find out how it performs on dune sand, and of course each obstacle and engine/tire/diff ratio combination will probably have a different ideal ratio...
Gut feel tells me I would still have preferred the 3.73, but that the 2.86 is probably a big enough improvement. And there may be issues with the 3.73 that I am unaware of.
The one unfortunate is that since I got the gears already fitted to a transfer case, I did not dismantle in order to measure and draw them up... And there's just no way I'm taking them out again.
Re: low range gears
Thank you for the update!
I would love the 85% gears.
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Re: low range gears
Post by davidvdm »
Makes me feel optimistic about my 4.2 gearing..
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
Reenen
Full Name: Reenen Kritzinger
Nickname: Reenen
Home Town: Greyton
Current 4x4: SFA Hardbody
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
88 Isuzu RD28 Nissan
1978 300D Merc RD28 Nissan
Been thanked: 125 times
Re: low range gears
Post by Reenen »
Nie patrol nie, maar ek is besig om n bietjie stadiger ratte in my W123 300D platkar in te sit.
Net ter verduidelikking, n stock safari het omtrent n 35:1 ratio in 1ste low, met sy 4.88 difs.
My merc kry nou 348:1... dit is 10 keer stadiger as my safari. En 37" bande...
Stefaansie
Full Name: Andre Vorster
Nickname: André
Home Town: Benoni
Been thanked: 9 times
Re: low range gears
Post by Stefaansie »
Reenen wrote: 21 Mar 2018 04:01 Nie patrol nie, maar ek is besig om n bietjie stadiger ratte in my W123 300D platkar in te sit.
Ek was baie lui met wiskunde op skool, maar, daai klink vir my na n 100 keer stadiger. Of is ek verkeerd?
'96 SGL-D PATROL (GQ)
ECHO 3
'07 SUZUKI BOULEVARD 1800
'06 YAMAHA 700 RAPTOR
Reenen
Nickname: Reenen
Home Town: Greyton
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
Re: low range gears
Post by Reenen »
Stefaansie wrote: 21 Mar 2018 09:22
Jy was lui ja, en verkeerd.
35x10 is 350:1
Re: low range gears
So it looks like I will end up importing gears...
Shipping is madness.
Re: low range gears
Jp Piet het n stel waarmee hulle besig is gee net kans
Re: low range gears
Dankie man...
Weet jy watse % gears?
Re: low range gears
Mnr PC...
Wat maak jy???
:woo:
