Posts: 3359 Joined: 23 Nov 2014 14:20
Has thanked: 244 times
Been thanked: 219 times
Post
by SJC » 16 Apr 2018 14:19
iandvl wrote: ↑ 30 Jun 2016 10:17
Right. Part numbers and similar.
Beading Trim, I purchased from Pro Auto Rubber in Pretoria. 328 Rebecca Street, Pretoria. 0123272757.
Part number: PR178.
Description: TRIMMING EDGE.
Cost: R16.93 per metre.
sien die prys het intussen bietjie op gegaan. Dis nou R22.50 per meter (excl. vat).
(En R150 om in Sabie af te laai...)
Post
by SJC » 20 Aug 2022 20:46
This is on a GQ's flares: How would you re-attach this bracket to the flair if it broke loose?
Got a few of these that came loose.
Posts: 6157 Joined: 10 Sep 2010 07:21
Has thanked: 1135 times
Been thanked: 1045 times
Post
by Peter Connan » 21 Aug 2022 06:53
There is no way to do it such that it will last.
One could make new brackets from aluminium flat bar that that extend all the way to the outer edge of the flair and rivet them on but it will be ugly and easily destroyed.
I am in the process of replacing my flairs with rubber ones. It as an extrusion that is available from 4x4 direct. Unfortunately it does mean drilling some holes in the car, but you drill into the bottom (rolled-over) edge of the wheelarch, so not too unsightly.
mvcoller
Posts: 654 Joined: 07 Apr 2009 07:13
Full Name: Malcolm van Coller
Nickname: mvcoller
Current 4x4: 2008 3.0 Di Patrol GL and 1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post
by mvcoller » 21 Aug 2022 09:47
Peter Connan wrote: ↑ 21 Aug 2022 06:53
Peter, you know the saying...... without pictures it did not happen!!!
Post
by SJC » 21 Aug 2022 10:00
one of these?
Post
by Peter Connan » 21 Aug 2022 15:42
Yes. I have the one on the left.
Post
by SJC » 24 Aug 2022 21:17
6 meter enough?
Post
by Peter Connan » 26 Aug 2022 17:37
Ja, behoort te wees. Maar net-net.
Post
by SJC » 26 Aug 2022 18:34
sal jy asb vir on prentjies opsit wanneer jy dit doen?
Sal graag wil sien hoe dit uitkom.
Post
by Peter Connan » 27 Aug 2022 10:17
I did the rear axle before the river trip. Didn't have enough material to do the front axle as well.
