Over heating problems
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Re: Over heating problems
Post by Wilkie »
Kyk ook of jou waaier band nie miskien gly nie en dan wanneer jy jou aircon aansit gly dit nog meer :think:
Carel
Full Name: Carel Vos
Nickname: Carel
Home Town: Germiston
Current 4x4: 84 Safari
2001 Patrol 4.5 GRX
Been thanked: 10 times
Post by Carel »
My Safari se temperatuur het die laaste ruk bo normal gestyg en by nadere ondersoek was die rubber op die "radiator cap" sleg gekraak en ge-perish. Saterdag 'n nuwe cap opgesit en sover bly die temperatuur onder normal. Ek het nog net nie ver gery om te sien wat hy gaan maak nie.
DanieG
Full Name: Danie Gerryts
Nickname: Danie
Home Town: Stilbaai
Current 4x4: 2013 Nissan Patrol 4.8 GRX A/T
2016 Ford Ranger 3.2TDCi 4x4 A/T Supercab
Has thanked: 37 times
Been thanked: 9 times
Post by DanieG »
DanieG wrote: 11 Jan 2018 08:11 Hi Josh
Mine did not overheat either, I had to fix a pipe and refill (partially). Do you run the engine while bleeding or how do you go about it?
OK, about time I give feed back.
I bled the cooling system a few times at the back at the little rubber cap as well as at the screw at the front of the cylinder head. Every time I found some bubbles coming out again.
I do not drive the Patrol so often, but it seems that both the problems of the bubbling sound and the heater turning on and off by itself, have been solved.
Danie Gerryts
Excellent news
