Radio Programming Day 15 July at Base 4
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 719 times
Re: Radio Programming Day 15 July at Base 4
I will make sure there is coffee. See all Saturday.
- Oetie
- Full Name: Leon Fouche
- Nickname: Oetie
- Has thanked: 395 times
- Been thanked: 152 times
I may make it after all, returned earlier from Lagos. It now all depends on what the wife has planned for tomorrow....iandvl wrote:I will make sure there is coffee. See all Saturday.
Please remember the DVD as discussed earlier.
ORRA - L65
HAM - ZS6LEF
Tlou - 2009 Patrol TD42T
ORRA - L65
HAM - ZS6LEF
- Has thanked: 1141 times
- Been thanked: 1049 times
Hope you guys enjoy!
- Rhett
- Nickname: Rhett
- Home Town: Heidelberg
- Has thanked: 163 times
- Been thanked: 78 times
Thank you Ian
Was a good day out of the city
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
- iandvl
- Nickname: Ian
Thanks everybody - was fun.
Special thanks need to to Rhet - your adapter saved the day!
- iandvl
- Nickname: Ian
A final note on this:
Those that were there will be familiar with the fact that I had to do some extra-special haxory to get the Bosvarks programmed. Basically, with the end-user software, one cannot easily change the frequency of the channels. I had to save a default configuration, edit it with a hex editor, and re-upload to the radio to get the stuff to work. One can also not set the output power with the end-user software, which means the user needs to do this manually, after powering on.
I've done significant digging into the Bosvark radio file format, and I think we're eventually in luck. I think we may be able to program them so that they are permanently in the correct "power" mode. I do, however, need on to test with, but I'm probably not going to have a chance to do this before River Trip. We'll make another session at the next club outing.
Once again, thanks. Was epic, and good to see everyone again.
- Full Name: Fanus
- Has thanked: 249 times
- Been thanked: 219 times
What, or why does a bosvark needs to be programmed?
Mine is running on standard settings, does it mean that mine wont communicate with the "programmed" bosvarks?
What is the benefit of this?
Sorry, maybe a dumb question, but just had to ask...
- iandvl
- Nickname: Ian
Technically, the BosVark does not need to be programmed - if everyone is using BosVarke.SJC wrote:What, or why does a bosvark needs to be programmed?
The issue cropped up with River Trip last year. Several guys had radios programmed by Jan. Several others didn't. Some people used Zartek - others used Bosvarke or Baofeng. Resulting in lots of confusion, and lots of people not being able to talk to each other. My idea was to program the radios as per Jan's frequencies, and this means that everyone at RT would be able to speak to each other on the same channels.
For what it is worth, the first 9 channels are identical to the factory standard bosvark channels (if I recall correctly).
- FordGuy
- Full Name: Chris Vercuiel
- Nickname: Chris
- Home Town: Roodepoort
- Current 4x4: Super Ranger
- Has thanked: 30 times
- Been thanked: 50 times
Ian
wil net baie dankie se vir jou tyd wat jy saterdag aan ons afgestaan het.
was ook lekker om nuwe gesigte te ontmoet.
lekker DAG
lekker DAG
- iandvl
- Nickname: Ian
Chris,FordGuy wrote:Ian
lekker DAG
Glad nie moeite nie. Was lekker gewees. Net bly ek kon die goed redelik uitsorteer.
