how much does your Patrol weigh?
Re: how much does your Patrol weigh?
HAHAHA.... We will now call you Peter "Mugg & Bean" Connan...... Put more.... no more
- Full Name: Wietsche Swanepoel
- Nickname: Wiets
- Home Town: Delmas
- Current 4x4: Nissan Hardbody
Nissan Patrol - Home Language: Afrikaans
- Been thanked: 12 times
Het my Patrol op die weegbrug gehad vol tenks petrol en soos hy maar altyd ry niks kampgoed in nie het 3180kg geweeg dis omtrent 300kg swaarder as wat die ding mag wees met almal ingelaai. As jy hom gaan laai om n toer te vat of die rivertrip gaan jy baie naby wees aan die 4ton maklik.
- Dungbeetle
- Full Name: Rudolf
- Nickname: Dungbeetle
- Home Town: Ellisras
- Has thanked: 69 times
- Been thanked: 70 times
No idea what my Patrollielorrie weighs
But I can say that when I go for tyre rotate/change/balancing often the lifts at workshops really struggle and some refuse to lift
2012 NP300 DC - platkar
- Rhett
- Nickname: Rhett
- Home Town: Heidelberg
- Has thanked: 163 times
- Been thanked: 78 times
I've never weighed mine, but after reading this thread I'm quite excited to check the figures. The N3 weigh bridge is 3km from home, I'm going to try on the weekend. I have factory front and rear bumpers, full length roof rack and a pretty light weight drawer system. I'll post figures if I get a chance.
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
- Dungbeetle
- Full Name: Rudolf
And if the readings and your licence disk are in conflict you are basically handing yourself in for prosecution......Rhett wrote: ↑26 Nov 2019 08:33 I've never weighed mine, but after reading this thread I'm quite excited to check the figures. The N3 weigh bridge is 3km from home, I'm going to try on the weekend. I have factory front and rear bumpers, full length roof rack and a pretty light weight drawer system. I'll post figures if I get a chance.
- Rhett
- Nickname: Rhett
True storyDungbeetle wrote: ↑26 Nov 2019 16:01 And if the readings and your licence disk are in conflict you are basically handing yourself in for prosecution......![]()
Rhett
- Spike
- Full Name: Spike Pretorius
- Nickname: Spike
- Home Town: Milnerton
- Has thanked: 77 times
- Been thanked: 87 times
I don't get the logic of using a station wagon as a base for a every-bell-and-whistle overlander. A full tank of juice and a vetgat in the passenger seat and you're exceeding GVM already.
Even a bakkie rolling chassis gets heavy quickly when you start throwing accessories at it. I have bakkies hovering at max GVM with just their "standard" kit (bullbar, winch, rocksliders, canopy, drawers, recovery gear, full tank of juice, two vetgat occupants, etc) and without loading any actual cargo yet
Sardonic Fattist
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
- Been thanked: 97 times
Had "The Firetruck" on a weighbridge on Friday.
2 600 Kg with full fuel tanks.
Tare of 2 275 Kg is about right if I drain all the fluids and take into account the extras on it.
my bakkie went over the scale at the dump on thursday 4.5 ton ...thinks i loaded a bit much
- Full Name: Fanus
- Has thanked: 244 times
- Been thanked: 219 times
For interest sake the tare weights on the different models:
GQ (TB42) - 2076
GQ (TD42) - ?
GU (TB45) - 2308
GU Pickup TD42ti - 2285
GU Pickup TD42 - 2275
GU TD42 Wagon - ?
GU 3.0 CRD - 2392
GU TB48 - ?
Weight difference between auto & manual models?
GQ (TB42) - 2076
GQ (TD42) - ?
GU (TB45) - 2308
GU TD42 Wagon - ?
GU 3.0 CRD - 2392
GU TB48 - ?
