1988 Safari 2.8 petrol
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: 1988 Safari 2.8 petrol
Post by JoshJ »
Wilkie wrote:Josh are you looking for booster or master cylinder spares..?
Howzit wilkie, i am not sure yet. The brakes is very poor. So I'll have to go through the system and see whats up. I was asking cause I might end up needing spares for the booster and wanted to know if spares are availible. Do you have a spare booster?
Being alive is a Blessing!!
Joshua
JoshJ
Nickname: Joshua
Post by JoshJ »
Dankie vir die info op die brieke Herry.
Daai canopy van jou werk baie mooi. Ek sal kyk na daai opsie op n stadium. :thumbup:
Joshua
JoshJ
Nickname: Joshua
Post by JoshJ »
So I had some time to fiddle with the safari. It does have a 38 weber. So now I must just find a service kit for it and also what jets sizes are correct for it. The plugs are also wrong.....
It seems like the choke works on water temp. Is that correct? I also need a new carb foot piece. The current one is cracked.
Joshua
Carel
Full Name: Carel Vos
Nickname: Carel
Home Town: Germiston
Current 4x4: 84 Safari
2001 Patrol 4.5 GRX
Been thanked: 10 times
Post by Carel »
Josh, ek gaan ongelukkig nie meer met die Safari Secunda toe nie. Ek sukkel nou al geruime tyd met die Safari wat petrol gebruik, meer as gewoonlik, en dan het hy geen krag nie. Verskeie ouens het al raad gegee en gewerk aan die Safari en nou is daar iemand wat heel moontlik die fout gekry het, maar die Safari sal nie reg wees teen Saterdag nie. Ons sal wel een of ander tyd bymekaar kom en vergelyk of dit wel 'n Meano conversion is.
JoshJ
Nickname: Joshua
Post by JoshJ »
Baie dankie Carl. Sterkte met jou Safari. En ek hoop jy het n lekker naweek :salute:
Joshua
JoshJ
Nickname: Joshua
Post by JoshJ »
Hi Matt. Thanx for your reply. I got a nice sorted 38 weber carb from Boogyman. And a couple of pointers. I also got an adapter plate from Dawid. So it seems I am sorted. I will keep you posted.
Joshua
Josh .. hallo. I THINK they are still there .. not too sure but in Pretoria Church Street, next toe the "Lion Bridge" is/was a Carburator dealer. They specialise in WEBER .. but I got THOR's refurbish kit for the NIKKI Carb from them .. and not expensive either. [THOR being a 4,2 Petrol Patrol]
LOBO was converted to fuel injection way back .. the Weber got me stuck on a steep incline with the float chamber running empty
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
Hi Josh I do have a spare booster and some odds and ends :thumbup: :thumbup:
JoshJ
Nickname: Joshua
Post by JoshJ »
So I serviced the carb with a kit. Chuck the ford air filter pan and installed n small pancake filter. Cleaned the plugs. Adjusted the gaps. Checked the oil. Found the dipstick telling me that theres almost double the amount of oil needed in there :surprised: .
Drained it off in increments to the correct level. I reconed thats where the exhaust smoke came from at high revs. Topped up the brake fluid. After all was done I took it for a spin. It pulls beter and refs more smoothly, but not there yet. Got her up to 5500rpm in fourth gear. Dont trust the speedo yet. :lol:
Smoke seems to be gone after a long hard drive. But then....... I experienced the death wabble on braking. I thought ahh hell now Im gone. Totally out of control. I went off the road and just let it be.....
Eventually it stopped. Phew scary. Ha ha ha. So that needs sorting. Any tips on where to look first will be apreciated. There is also a noise comming from the rear. Not a grinding noise but more like something rubbing. And gearbox wines. So any recommendations on that will also be apreciated :thumbup:
Joshua
JoshJ
Nickname: Joshua
Post by JoshJ »
Thanx wilki. I'll keep that inmind. QQQ
Joshua
