Terrain Tamer Parts
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Re: Terrain Tamer Parts
Post by Marino4x4 »
erasmusdries wrote:Marinus ,I see the parts are labelled GQ.Will they fit on the 2000 diesel non turbo model GU as well?I am interested in the radiator hoses and belts
Hi Dries
Die Radiator Hose Kit gaan ongelukkig nie pas nie, maar die belde behoort te pas.
:thumbup:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Been thanked: 430 times
ricster wrote:Total cost if I remember correctly was R5700...... :surprised: :surprised: :surprised: :surprised: :surprised: what ??....just for tips. I paid R425 each a few years back...... thats R2550 for complete set of six complete injectors !! from SAC in Centurion !!
I did mine 2 years ago at Bosch, cost me just under R2,000 and that was also for 6x new tips
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
Marino4x4 - Well done on this great initiative. I have watched heaps of vids with terrain taimer products and always thought it would be so great if we had stock of such kits here in south africa.
Guys, there was a massive hijacking of this thread earlier, which makes searching through original content alot harder, please can you start another thread (ie: personal diesel injector issue discussions), as it helps keep this thread true to the topic (advertising definitive kits), and doing so also helps future users to find your discussions through the search which could help them in future, which would otherwise not have been found. No finger pointing from my side, we all guilty at times, just trying to peacefully find a helpful solution. Thanks.
As for kits, i think its great, i will certainly be looking at hose kits. But looking forward to seeing what else you bring in . Excellent stuff guys! just when i was getting down about the stuff locally available for patrols, now this, fantastic.
Russ, I suggested to Marinus that he keeps updating that first post with available products and pricing.
In that way, perhaps "pollution" of the thread later on is less important?
Russ Kellermann
Perfect.
Thanks lads.
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Good day
I have had some interest from forum members in Terrain Tamer parts. As you can imagine it is difficult to quote or import these parts in small quantities or one-one. Please find a list of parts bellow and their cost if they are imported together and via sea fright. Please note this takes 6-8 weeks. Please have a look on the Terrain Tame website (http://www.terraintamer.co.za) if there are parts that you might be interested in, but that is not listed below.
4H501 Front bearing Removal and Installation Tool GQ, GU R340
SH13 Repair Kit Steering Knuckle GQ (Both Sides) R2760
SH14 Repair Kit Steering Knuckle GU (Both Sides) R2530
TSBK0028 Bush Kit Panhard Rod Front and Rear GQ, GU R630
TSBK0012 Bush Kit Caster Correction 2.5 Deg. 25-50 MM Lift GQ, GU R2015
TSBK0013 Bush Kit Caster Correction 3.5 Deg. +50 MM Lift GQ, GU R2580
N62870 Adjustable Trailing Arms Upper Pair GQ, GU -2003 R4560
A9684/A9635 Harrop E-Locker Front/Rear R22 500
TB42 GQ
NFK13 Filter Kit R520
11220-10J00 Engine Mount Front 2 Bolt R/H, L/H (Each) R520
11220-10J10 Engine Mount Front 4 Bolt R/H, L/H (Each) R520
11320-00J06 Engine Mount Rear R/H, LH. (Each) R690
DB321TT Disc Pad Set Front R590
DB1146TT Disc Pad Set Rear R590
40206-37J01 Disc Rotor Front (Each) R1300
43206-05J04TT Disc Rotor Rear (Each) R860
TTCK6831HP Heavy Duty Clutch Kit incl. Spigot Bearing R10 300
WBK4043 Wheel Bearing Kit Front (Each) R1090
HK201 Radiator Hose Kit R510
AVM445 AVM Free Wheel Hub 31 Spline 6 Bolt (Set) R3580
TD42 GQ
DB1257TT Disc Pad Set Front Twin Piston Caliper R590
TTCK6830 STD Clutch Kit Incl. Spigot Bearing R6370
TTCK6830HP Heavy Duty Clutch Kit Incl. Spigot Bearing R10 300
HK200 Radiator Hose Kit TD42 Diesel 4.2L Non Turbo R560
11065-10T01 Glow Plug (Each) R250
NFK1 Filter Kit R1130
TB45
DB1148TT Disc Pad Stet Rear R590
DB1361TT Disc Pad Set Front R590
40206-VB001 Disc Rotor Front (Each) R1840
11220-VB000 Engine Mount Front GU (TD42TI, TD42, TB45) (Each) R640
HK205 Radiator Hose Kit R650
TD42TI Bakkie
NFK4 Filter Kit R1125
HK212 Radiator Hose Kit R1095
TB48
11210-00J06 Engine Mount Front GU TB48 (Each) R935
HK328 Radiator Hose Kit Incl. Heater Hoses R3350
Please indicate if you are interested in the parts. We can start a list and as soon as there is enough interested parties we can arrange to import the parts.
I also adjusted the costing in the original post to the costing above.
(PS.: If any forum rules are broken by this post please feel free to remove or report this.) :thumbup:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Please have a look, our website is active and orders can be placed through it.
Terrain 4X4 Parts
Marinus
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Dis awesome Marinus! Glo hierdie gaan n groot sukses wees
Has thanked: 189 times
Been thanked: 270 times
Sal gaan loer :thumbup:
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Good day
We added the following parts to our range of stock:
Engine Mount Front GQ: R800
Engine Mount Back GQ, GU: R880
Air Filter GQ TB42, TD42, GU TD42: R350
Radiator Hose Kit GQ TD42 N/A: R900
Radiator Hose Kit TD42 Turbi Intercooled: R1760
Radiator Hose Kit ZD30DDTI 2000 - 2006: R1050
Radiator Hose Kit ZD30DDTI Including Heater Hoses 2006 -: R2780
Flash Lube Catch Can Pro: R3785
Radiator Hose hit GU TD42 N/A: R1510
Radiator Hose Kit GU TB45: R1165
Radiator Hose Kit GQ TB42: R900
GU TB48, ZD30 Cabin Filter: R180
GU TB45 Fuel Filter: R340
GQ TB42E Fuel Filter: R350
Nissan Safari Fuel Filter: R185
Fuel Filter TB42S: R180
Please contact us if you require any other parts. We still have parts available in the thread or we can ship parts with our next order.
Marinus
Terrain 4X4 Parts http://www.terrainparts.co.za
Patrol 4.5 GL 1998
Terrain 4X4 Parts
