marakasmalan
Posts: 321 Joined: 20 Oct 2010 17:22
Full Name: Marnus Malan
Nickname: marakasmalan
Current 4x4: '94 Patrol SGL
Has thanked: 4 times
Been thanked: 16 times
Post
by marakasmalan » 03 Sep 2014 09:37
Michael wrote: Dont you worry, I will make sure I get the GPS speed on camera
How do you connect the drill to the GPS?
Tinus lotz wrote: Me thinks a top end run for some patrols is a great idea...mmm where and when ????
See the event information: Diesel & Sparks. There is a lot of brave talk here so lets see if they have the balls to back it up!
JoshJ
Posts: 986 Joined: 30 Nov 2013 16:16
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Post
by JoshJ » 28 Sep 2014 21:53
Hi Michael.
Only came across this thread now. VERY WELL DONE
now I understand why Tinus talks so highly of you. EXCELLENT
Being alive is a Blessing!!
Joshua
JoshJ
Nickname: Joshua
Post
by JoshJ » 28 Sep 2014 21:57
Don't mind these guys with there 4.8 speedsters, they are only good from robot to robot. From Gauteng to Cape town the oil burners wil win. Simply because they dont need to fil up every 300k's
Joshua
Posts: 5853 Joined: 13 Jan 2010 11:16
Has thanked: 591 times
Been thanked: 472 times
Post
by ricster » 29 Sep 2014 08:26
Josh.... you rock my friend....hahahaha
Long live the oil burners...... real trucks don't have spark plugs...plain and simple !!!
IanT
Posts: 1234 Joined: 17 May 2013 10:43
Full Name: Ian Temperley
Current 4x4: 1995 GQ 4.2 Petrol (Turbo Charged) (Hell Boy) 2008 4.8 GRX Umkombe
Been thanked: 92 times
Post
by IanT » 29 Sep 2014 08:37
Post
by ricster » 29 Sep 2014 08:59
Posts: 6155 Joined: 10 Sep 2010 07:21
Has thanked: 1129 times
Been thanked: 1043 times
Post
by Peter Connan » 29 Sep 2014 17:17
Ai tog Cedric, why do you slander us like this.
Rod's is a 4.2 Diesel. Normally aspirated, I believe, which will acount for his arrival date. I mean time...
Posts: 2506 Joined: 05 Mar 2014 14:39
Has thanked: 192 times
Been thanked: 432 times
Post
by Michael » 29 Sep 2014 17:54
JoshJ wrote: Hi Michael.
Thanks so much Josh, I really put in alot of time and love into this rebuild. And for me it is worth every second!!
Post
by Michael » 29 Sep 2014 18:03
Another update on how my mods are going
I finally got my rear mud flaps cut and installed....
Boost gauge installed and working perfect
On the way to the ralley event Tinus drove behind me and noted that my Patrol makes ZERO smoke under boost which points to the engine running a bit lean.
So after the boost gauge install I gave the fuel screw another 1/4 turn for more fuel and WOW!! So much more alive!!
The boost now come in at around 1,300rpm and I have 0.7bar at 2,200rpm. EGT seems slightly higher but still way safe and didnt go over 510deg on the highway
Post
by Michael » 29 Sep 2014 18:05
Oh yes and before I forget.....
160km/h oh yes!! 20140924_085531.jpg (2.03 MiB) Viewed 3904 times
