8-12 August River trip 2019
Would you take a trailer on the river trip?
Poll ended at 04 Aug 2019 10:42
Yes
2
8%
No
11
46%
Are you nuts
11
46%
Total votes: 24
izakjbrt
Full Name: Izak Joubert
Nickname: Izak
Home Town: Ramsgate
2012 Patrol 4.8 GRX (MA-trol)
Has thanked: 235 times
Re: 8-12 August River trip 2019
Post by izakjbrt »
martyn wrote: 08 Apr 2019 10:58 Dead standard would be great. Just some recovery points, straps and shackles, in case someone else gets stuck.
Cool, need some recovery points.....as I don’t think it’s standard on a patrol, only the toe down hooks
2007 Nissan Patrol 4.8 grx
izakjbrt wrote: 08 Apr 2019 11:07 Cool, need some recovery points.....as I don’t think it’s standard on a patrol, only the toe down hooks
You should have the factory fitted recovery hook at the front (that is standard). At the back, you have the pintel hook.
izakjbrt
Nickname: Izak
Home Town: Ramsgate
Post by izakjbrt »
iandvl wrote: 08 Apr 2019 11:36
Thanks Ian, will they suffice? I’ve read up on this on the interwebz and while some say it’s fine, the others say it’s not sufficient
izakjbrt wrote: 08 Apr 2019 11:40 Thanks Ian, will they suffice? I’ve read up on this on the interwebz and while some say it’s fine, the others say it’s not sufficient
The front recovery hook - most definitely.
Quoting our resident expert...
The pintel hook should be fine. However, some people did raise concerns regarding the welding on the hook in the past, if I remember correctly. If you're worried about it, ping Tinus for a replacement pintel hook. He had some aftermarket ones at some point.
Edit: Found a photo. The aftermarket pintel hook replacement looks as follows:
izakjbrt
Nickname: Izak
Home Town: Ramsgate
Post by izakjbrt »
iandvl wrote: 08 Apr 2019 11:44
Awesome, done and dusted. Radio is on the list. And then some straps. Thanks dude
petrol
Full Name: Martin Koorts
Nickname: Martin
Has thanked: 5 times
Been thanked: 15 times
Post by petrol »
Hello
Sit my naam ook op asb.
Nissan KingCab
Full Name: Danie
Nickname: Danie
Home Town: Madibeng
Home Language: Afr
Has thanked: 45 times
Been thanked: 26 times
Post by Nissan KingCab »
Hi Dirk,
Sit my naam ook op, ons is verseker weer in. Dit is 'n lekker familie naweek waar mens lekker kan ontspan.
My vrou het bestuur wat dit vir haar ook meer interesant maak. Die kinders geniet dit ook baie om in die sand te speel en op die Patrol se dak.
River trip 2018 (2).jpg (287.93 KiB) Viewed 6365 times
izakjbrt
Nickname: Izak
Home Town: Ramsgate
Post by izakjbrt »
Voeg asb Nols en Liezel by. Met n Ford Ranger
Charles Duckitt makes a pinter hook identical to original Nissan item .. contact him if yo meed one
O-ja, tel my en Dwergie ook by asb..
Herstel .. ons gaan NIE die een maak nie .. ek is in Zambie op Uitreik [gan darem draai maak Liuwa plain ook]
