Project Snowy met n turbo
Re: Project Snowy met n turbo
Looks a lot like the ones in my bakkie ...mabe look at whar they have for the ud40 ? Just to compare?
ricster wrote: 19 Feb 2018 15:16 They better bloody work... I'm not opening my motor in a hurry..... :lol:
Who knows which vehicles came out with a N/A TD27?
Hardbody 2.7 n a pick up many moons ago
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 20 times
Been thanked: 97 times
Post by David M »
Tinus lotz wrote: 19 Feb 2018 16:27
Yep.... Was actually pre Hardbody and was called 1 Tonner. Had one as a company vehicle for a while but the only way you could get 120 km/h was by throwing it out an aeroplane :rolling:
Has thanked: 1136 times
Been thanked: 1047 times
Not an expert on Diesels, but:
Piston weight and RPM combined is the biggest contributor to engine wear once the engine is up to working temperature. As far as I am concerned, lighter must be better.
But, the above only counts if the crown height is the same, because if not the compression ratio will be reduced.
Now on to balancing and blueprinting:
1) Manufacturers do balance their engines. But on slower-revving engines and "working" engines, they tend to do only balance statically, which is proven to be a fairly inaccurate process. Also, I suspect their tolerances in this regard are far wider than those of specialist balancers, or when they are building high-revving sportscar engines.
2) As aluded above, dynamic balancing is a far more accurate process.
3) Blueprinting is a process where the dimensions of an engine's components are "normalised". They can be normalised with respect to the original manufacturing drawings, or just with respect to each other. For example the conrod's centre distances may be measured, and re-machined such that they are all the same, or they can all be made to be the exact "factory" length. Typically, the parts in question would be the crankshaft, conrods, pistons (crown height), combustion chambers, pushrods, rockers, valves and so forth.
4) Blueprinting may or may not include dynamic balancing. It must include static balancing as a minimum.
5) Both these processes will improve smoothness, rev-ability and lifespan of an engine.
Dynamic balancing is a fairly quick process, thus inexpensive, whereas proper blueprinting is very labour-intensive, thus quite expensive.
Andre, those are quite good looking pistons. Would love to have a look at them to see what quality they are.
I prefer to use Nural (previously known as AE) pistons, but they are quite pricey, but also use the Autopower ones with great success. The Nural's are an exact duplicate of the UD40 pistons and they have the 4mm oil ring where the TD42T bakkies have the 3mm oil ring.
The Autopower ones do not have the oil journals in the piston head, but does have the alfin insert and seem to take the beating.
Cedric, do you perhaps know which brand pistons you put in your engine?
There are plenty of TD27 NA engines going around, but I cannot say in which vehicles they were used. I do know of heaps that were used in generators and have been looking at loads of secondhand ones as I was looking to find more top covers on the diesel pumps for the boost compensators......
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post by mvcoller »
The Nissan 1 Tonner bakkie used the 2.7 NA engine, I would imagine it was actually designated a D27 not TD27. Later a local mod at the Nissan factory in Rosslyn, saw turbos fitted to the normal D27 engines with huge overheating problems built in. As far as I am aware, no locally produced 2.7 Nissans, be it 1 Tonners or Sanis came with a "genuine" TD27 engine.
The only "REAL TD27 or TD27i " (the i indicating "intercooled") engine came in the Spanish built Nissan Terrano 2.7TDi, available locally from about 1998 to 2001. Jap Imports bring in identical engines to the Terrano's TD27 engines from Japan.
I would imagine the best 2.7 pistons would therefore be imported TD27 pistons.
Tinus lotz wrote: 19 Feb 2018 15:03 20180219_142210.jpg20180219_142210.jpg
Daai lyk soos die pistons op Michael se rak???
Michael wrote: 19 Feb 2018 18:54 Cedric, do you perhaps know which brand pistons you put in your engine?
Off hand, no clue what brand. All I do know is that Frans sourced them from Masterparts in Cape Town for me. They were put into a box and shipped up to Jhb for me. I don't even think I have the box they came in.... bearing in mind the engine overhaul was done just over 7 years ago. I do know it has the oil channels for the squirters to blast oil into them.
Andre_gtr wrote: 19 Feb 2018 15:25 I found a set of pistons that have caught my interest for a td27t, they are shorter than the normal td27 and td42
better lighter or not, at least they both have the cooling gallery?
TD27t not sure about the shorter skirt and pattern on the top, but they are anodized on top
td42 the skirts are considerably longer and the design on top is different
any comments from the experts??
Wat vra hulle vir die kit??
Shipping??
Andre_gtr
Full Name: Andre Jacobus Strydom
Nickname: Spiedkop
Home Town: utrecht
Current 4x4: ford ranger 3.0
Been thanked: 5 times
Post by Andre_gtr »
hugejp wrote: 20 Feb 2018 16:47
Shipping??
Nie seker nie ek het n vriend oorsee wat vir my n prys gaan kry
