L28 Na RD28
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 719 times
Re: L28 Na RD28
I would suggest getting hold of Engines and More in Hartbeespoort. They will deliver, and I have only heard good things about them. 0122532485
Not sure whether they would have an L28 in stock, but it does not hurt to give them a call and ask.
I'll keep my eye out in the mean time in any case.
- Full Name: Reenen Kritzinger
- Nickname: Reenen
- Home Town: Greyton
- Current 4x4: SFA Hardbody
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
88 Isuzu RD28 Nissan
1978 300D Merc RD28 Nissan - Home Language: Afrikaans
- Has thanked: 4 times
- Been thanked: 126 times
Re: L28 Na RD28
By the way ..... When you get a chance, check this link out. Copy and past it into a new thread. It just helps us know a little more about you and your vehicle..... have a look here http://patrol4x4.co.za/viewforum.php?f=33
- Full Name: Johann van den Berg
- Nickname: Johann
- Home Town: Akasia Pretoria North
- Current 4x4: Nissan GQ 4.2D High Roof
Nissan 4.8GRX Adventure
Nissan Safari bakkie 1989
Landcruiser Pick Up 4.5 - Home Language: Afrikaans
- Been thanked: 5 times
Re: L28 Na RD28
Hier le n eersteklas L28 naby my in n scrapyard Ek dink jy sal hom kan kry vir R6500 as jy wil he ek moet uitvvind. In Pta noord
- Full Name: greg justus
- Nickname: juice
- Home Town: benoni
- Current 4x4: patrol 2001
safari 1984 wagon
safari 1982 wagon - Home Language: english
- Has thanked: 1 time
- Been thanked: 12 times
Re: L28 Na RD28
Morning
I changed my safari from a L28 to a rd28 motor many years ago
The bell housing is the same but it does not bolt directly on to the motor' there is one of the main bolts on top that you have to weld up and redrill, most rd motor you can get are automatic, I have only every seen one at Japan auto that was manual. The L 28 flywheel hole pattenis the same and it bolts straight on ,so there is no Hassel's on the clutch side , the motor mountings will need to be fabricated, I use the old ones from the L28
And adjusted them with the bracket that come with the Rd motor.
Water pipes also needed to be rerouted , it needs a bleeder hole to make sure on to close to the head , had difficulty getting all the air out of the system
I also put a small turbo on it , more like a altitude compensated, with a boost of 0,5
Turn the fuel up on the pump , no android was fitted so it did smoke lower down and pull away
When buying the rd28 motor look out for the oil supply hole on the exhaust side , make life
A lot easier and shorter pipes for the turbo oil supply and the turo drain is also there are
Some have it some don't
And also a big intercooler in front of the radiator
The first motor I fitted was a dud , but wanted a diesel in the safari so I bought another (R4500
Then next one gave me many happy hours and trouble free
The old girl still starts at a swing of a key and get a run every now and again
But like any conversions there are snags , the motor without the turbo will be a real donkey for the farm, any other questions give me a call
regards Juice
regards Juice
- Nickname: Reenen
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
Re: L28 Na RD28
Juice beaam alles wat ek gesê het, behalwe dat die flywheel 1mm groter geboor moet word, en ringgear vervang moet word na rd ringear om diesel starter te vat
- Nickname: Reenen
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
Re: L28 Na RD28
Jaco het Saterdag n L28 by my opgetel. Hoop dit is straightforward inbou sonder snaakse probleme en dat sy safari gou sal loop.
- Newbie
- Full Name: Jaco Botes
- Nickname: Jaco
- Home Town: Kuruman
- Current 4x4: Safari L28 'Lohathla'
- Home Language: afr
- Has thanked: 5 times
Re: L28 Na RD28
Beste Reenen
Baie Dankie vir die opregte en eerlike hulp wat jy aan my verleen het!
ek waardeer dit opreg!
- Nickname: Reenen
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
