Bonnet for my 2008 Partol
Has thanked: 61 times
Been thanked: 258 times
Re: Bonnet for my 2008 Partol
mvcoller wrote: 02 Jan 2018 19:53 Exakirry Mac... the extra air "fills" the engine bay and prevents air from going through the radiator sufficiently.
Exellent previous post.
I’ve learned something.
On my v8 I kept the scoop on.
Temperature management is good for a conversion, but would be better if the scoop was closed.
This is the same reason the side wheel-wel rubber flap/covers are so important as well as the radiator cowl...
They all add up to ensure correct air flow through the radiator.
hugejp wrote: 03 Jan 2018 08:20 This is the same reason the side wheel-wel rubber flap/covers are so important as well as the radiator cowl...
So if there is no scoop, and cowl is right, and wheel-well rubber flap/covers are in place, where does the air go?
Just channeled behind the engine and through to the back?
Alex Roux wrote: 03 Jan 2018 09:31
Yip!
Hy trek deur agter toe en onder die kar uit.
