diff lock stuck on
biggles
Full Name: Steven
Nickname: Steve
Home Town: Durbanville
Current 4x4: GUII Patrol 4.8
Has thanked: 21 times
Re: diff lock stuck on
Post by biggles »
Peter Connan wrote:If it is only the actuator stem tht is broken, and presuming you are willing to wait a little while, send me the broken bits, and I will turn you up a new one?
The fork and the ring are also damaged due to the fork being loose in the diff. I am very lucky they didn't do any other damage.
But I did not think about having a stem made up... :think:
I suppose you would need the stem for measurements? It is still in the diff so that would have to come out.
:layrubber:
We have fixed a couple between us mamba and Wilkie sorted his out....mabe het a donar from dawid ? Sure they fixed it with a 4.5 one :think:
Yes, i will need the damaged bits for measurements.
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
Damnit guys!! I am justifying an e-locker... don't give me more reasonable alternatives!!! :lol:
Thanks for the offer Peter, I will be in namibia till end of August and then I will only be able to tear down the diff to get the stem... I am home for 2 weeks, so I will be without the troll for that time and then on break again in October...
Better to order the e-locker now, have it slipped in when I get back and then I can play with the troll sooner.
:layrubber:
Where are you ordering e locker from?
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
Tinus lotz wrote:Where are you ordering e locker from?
I contacted Marino and I have prices for ARB airlocker.
As a matter of interest the guys that installed my lockright were punting a generic air locked based on the ARB one. They had done a few installs but when I picked up the patrol they had changed their tune. One they installed was causing problems by randomly dis-engaging and they couldn't track the issue.
:layrubber:
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
:doh:
No e-locker for the patrol with the OEM difflock. That rules out e-lockers at the back for most of the SA patrols...
:layrubber:
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Also does not seem like there is much (or anything) available for a rear h260 LSD diff.... :thumbdown:
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
ARB or TJM airlockers are all that's left.
:layrubber:
