"The Firetruck"
Re: "The Firetruck"
You guys are funny, have not even finished the job yet and drag racing is on the agenda :lol:
Things are going well on the Firetruck, way more to be done than I hoped for....... but it is going to be worth it and I am sure David and his wife will smile a little bit wider when they drive it from now on.
Re: "The Firetruck"
Dice....waar wie wanneer.....ek is daar.... :lol:
Has thanked: 244 times
Re: "The Firetruck"
Michael wrote:You guys are funny, have not even finished the job yet and drag racing is on the agenda :lol:
Wat alles moet/moes jy op die bakkie doen?
Ek neem aan sy bakkie is selfde setup as myne?
(Want ek wonder maar wat kan nog op myne gedoen word sonder om n tweede verband uit te neem).. :wink: :lol:
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 20 times
Been thanked: 97 times
Re: "The Firetruck"
Post by David M »
Will post photo's tonight.
Rob Green Motorsport did the conversion while it was still new and I hope it is not their work that we uncovered but other clueless people thereafter.
1. The fuel filter had no water trap and a second fine filter was fitted. I removed the second filter, redid the plumbing, replaced the filter with the correct filter, fitted the water trap I got from Dawid and had to change the electrical plugs as they did not match. The electrics I did while Michael had the intercooler off. Voila - All jerking gone and a lot more power.
2. It had a BMC airbox fitted with a K&N inside that did not even seal and rattled around inside the box. Also not sealed to the snorkel. I fitted an airbox that I got from Dawid and redid the plumbing. I still need to seal to the snorkel and modify 1 aircon pipe but that is a job for another day.
The concern here was that the vehicle had effectively run without an airfilter for a while but it's saving grace is that it looks like it has not been used offroad much and has no oil trap fitted. This meant that the dust combined with the oil and was left in the turbo, pipes and intercooler but did not make it to the engine.
I am going to recondition the turbo in January as the vanes are pitted and rounded. And I had so much fun cleaning every pipe and the intercooler at Michaels's place. :thumbdown: :thumbdown: :thumbdown:
3. Michael changes the oil and oil filters and the oil is not at all bad for oil that has been in for 10 000 km.
So now everything is off and Michael's job should be easy and he starts by setting the fuel pump timing which was horribly advanced. White smoke from the exhaust which means it is not burning all the fuel. :thumbdown: :thumbdown: :thumbdown:
4. Michael has a set of reconditioned injectors which he fits. Smoke is still white. :thumbdown: :thumbdown: :thumbdown:
5.Michael removes the fuel pump which does not even have a gasket and replaces with a reconditioned fuel pump which he has. Of course the reconditioned fuel pump was set for 1 bar boost and +/- 200 kw so he needs to recalibrate. Black smoke!!!!!!!! :thumbup: :thumbup: :thumbup:
6. While Michael is down there and everything is off the valve clearances are set. 1 was too tight and the rest where too loose.
7. Now everything goes back together as well as fitting the oil temp and water level Madman sensors (It did not have those 2) and Michael will redo a bit of the turbo plumbing which he can elaborate on if he wishes.
So "The Firetruck" should be breathing fire by this evening and we will go steal Tinus's bakkie while he is in Moz so that we can use it as a comparison. :rolling: :woo:
Michael - Please correct or elaborate if necessary.
David M
Home Town: Midrand
Re: "The Firetruck"
Post by David M »
"The Firetruck" is back and haulin ar#e. EGT's climb when nailing it on long uphills but that should be sorted once the turbo has been reconditioned in Jan.
Re: "The Firetruck"
How high? (Egt's)
Re: "The Firetruck"
David, I think you covered everything :thumbup:
Biggest problem left id the turbo that needs to be reconditioned. It cannot produce the boost needed and now the engine runs too rich. From the tests I have done it only starts boosting at 1,600rmp and full boost is around 2,800rpm which is way too high.
On another td42 I worked on which has a similar sized turbo it already produced maximum boost on 1,800rmp which is what you want
Re: "The Firetruck"
Fanus, on you bakkie the biggest problem is the fuel pump.
You need a biost compensator and it is not cheap.
Here we pay worst case R9,800 for a xomplete pump rebuild, setuf of fueling and a biost compensator
Re: "The Firetruck"
SJC wrote:How high? (Egt's)
I set the alarm on 660deg
Re: "The Firetruck"
SJC wrote:
David M wrote:
Spotted at a dealer in Worcester and rumour has it is is coming up to Gauteng. And to make it even more interesting I have heard it has a lady owner.
Maybe the new owner would be interrested in doing a seat swap with me.... :eureka:
David M wrote:
Fanus - Will chat. I think it's a good idea and will chat with her after it arrives. Please post pic of yours.
Well, if you are interrested: My passanger seat with centre console etc. is currently removed.
Can arrange to get it to you, if you want to see if it fits? :eureka:
