Car not turning right
graham1
Full Name: graham robertson
Nickname: graham1
Home Town: Harties
Has thanked: 9 times
Been thanked: 100 times
Re: Car not turning right
Post by graham1 »
Glad I found this thread!
My 4.8 has this exact problem at the moment - it doesnt turn right as well as it does left - I looked like a real chop the other day pulling into a parking and the damn thing wouldnt turn sharp enough.
So I'll be under my patrol this weekend if anyone needs me :biggrin:
Graham, have you done anything (or had somebody else do anything) under your car recently?
That adjuster can come loose by itself but it's fairly unlikely?
I once had this happen after replacing the steering damper. Turned out it was a different length than the original, and I ended up moving the mounting bracket on the drag link to solve it.
Pieter B
Full Name: Pieter Botha
Nickname: Pieter
Been thanked: 97 times
Post by Pieter B »
Yes, disconnect the steering damper and try to turn again. It's more than likely an incorrect damper
graham1
Nickname: graham1
Home Town: Harties
Post by graham1 »
Peter Connan wrote: 27 Nov 2020 09:29 Graham, have you done anything (or had somebody else do anything) under your car recently?
Nope. That poor car has experienced serious neglect over the past year and a bit. :redface:
Its suspension is absolutely shot though, so, maybe the steering damper is doing something wierd as well.
It was strange, when I pulled into the parking, I definitely noticed its 'full lock' to the right wasnt enough. I reversed to straighten up, and turned right again and when I got to that incorrect full lock again there was a satisfying release, and I could turn it further.
I tested this morning and I get two full turns to the left, but only just over 1.5 to the right.
I don't think the steering damper can "go faulty" in a way that can cause this. First port of call: adjusting stops.
Digger
Full Name: Graeme Bath
Nickname: G
Home Town: Delmas
Current 4x4: 1998 Patrol 4.5 GL
Has thanked: 11 times
Been thanked: 11 times
Post by Digger »
Checked the Prepper Wagon out this morning also found a bit of a difference, 2 turns to the left and 1 and 3\4 to the right, will check it out when I do the brakes later, can only be stops, I hope.
Cheers G
