My '98 GU 4.2 TD
Re: My '98 GU 4.2 TD
The rocker or tappet gap will need to be re adjusted to the (I think) 0.32 mm gap to get it to spec, then all will be good again
- Been thanked: 432 times
Jip as Cedric said it makes no difference, you just set the valve ckearance back to 0.30mm and all is back to spec and the valves will open just as far as they did the day it started for the first time
- Full Name: Danie Terblanche
- Nickname: Danie
- Current 4x4: 2000 Nissan Patrol 4.2 diesel / DIY Turbo Conversion.
485 Nm@1300Rpm NA - Home Language: Afrikaans
- Been thanked: 1 time
Ek het hierdie gesprek aandagtig gevolg maar dit is nou stil.
Danie
Live while you’re alive!
