Rear coil spring tower braces
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Re: Rear coil spring tower braces
Post by davidvdm »
ricster wrote: 15 Feb 2021 10:56 I had the same problem.... I had the best solution to that problem. I built myself a new 7500mm deep x 6500mm wide garage with a 2465mm high garage door. I can now load my roofrack with RTT onto the Patrol in the garage from the Franklin hoist suspended from the roof trusses.... :biggrin: It makes life sooooo much easier. So there is never problems only solutions.... :rolling: :rolling: :rolling:
Hey, Hillbilly has not been able to fit under a garage door for many years now. He is like the dog that just got too much to be allowed to sleep in the house, and had to adapt to living outside. :rolling:
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
hahaha... hillbilly's have to stay outside.....
David, you can't build a garage high enough for Hillbilly ... :rolling: :rolling:
davidvdm
Post by davidvdm »
ricster wrote: 16 Feb 2021 08:23 hahaha... hillbilly's have to stay outside.....
Problem is the sun beats him to death. Nissan also makes the inside door panels from a plastic that melts and gets deformed at around 50degC. So guess what mine looks like in the West Coast sun that hits above 40deg in the shade here every few days. Even my clear coat on my paint job is coming off faster than it did in the last 5 years in Gauteng.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
Chukkie
Junior Member
Junior Member
Full Name: Gerard Schuite
Nickname: Chukkie
Home Town: Struisbaai
Current 4x4: Nissan Patrol 4.8 grx
Post by Chukkie »
OK So I installed the tower braces from Boss 4x4. Was the most elegant solution for me.
Again thanks to all for your inputs!
Gerard
Patrol 4.8 GRX
Francois Theron
Full Name: Francois Theron
Nickname: Francois
Home Town: Robertson
Current 4x4: 2006 Patrol 4.8 GL
Has thanked: 12 times
Been thanked: 29 times
Post by Francois Theron »
Chukkie wrote: 18 Mar 2021 14:50 OK So I installed the tower braces from Boss 4x4. Was the most elegant solution for me.
Would you mind supplying more info and some photos please?
Are these them??
