Suggested tyre pressure
izakjbrt
Full Name: Izak Joubert
Nickname: Izak
Home Town: Ramsgate
2012 Patrol 4.8 GRX (MA-trol)
Has thanked: 235 times
Re: Suggested tyre pressure
Post by izakjbrt »
Oetie wrote: 12 Mar 2019 08:00 There appears to be no golden rule.... conclusion is to play around to see what suits you and the vehicle the best.
It felt as if the car was hard on the road, hence the pressure question, but then I think it could rather be the new bilstein shocks doing their thing. I must also add that I went from a Pathfinder to the Patrol and may have a skewed view on ride comfort.
I think the pathfinder has an ifs axle, the patrol has a live axle. So it will not be as comfortable as the pathfinder, but
It will also not break if someone sneezes near it. Ronnie Dahl did a cool comparison on his YouTube channel in regards with live and ifs axles
2007 Nissan Patrol 4.8 grx
Has thanked: 193 times
Been thanked: 275 times
3 bar on tar.
But that 4.2 diesel is heavy in front and with the drawer sytem and fridges permanently in the back its always heavy.
Better fuel consumption on 3 bar for me
Has thanked: 1134 times
Been thanked: 1044 times
Live axles het baie meer "unsprung weight" as die Pathy. So hy gaan harder voel.
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post by mvcoller »
I have always run all my vehicle tyres at 2.0 bar, irrespective of what it was, from my first car, a 1963 1200 Beetle to my super fast Alfetta 2.0 Turbo and on all my 4x4s. These are a Sani, a Terrano, 2.8 Safari, a 4.2 GQ (with 33 x 12.5 x 15s), later with a Lexus V8 fitted, my current Pathfinder and also my current 3.0 Di Y61 Patrol. This does not often happen on the Y61 though, as it is only used of safaris and camping trips, with only the odd weekend away to a lodge or visit family and the pressures at 2.0 bar.
The only exception was in my Alfa 155 V6, that was fitted with 205/40 x 17 tyres. The front tyres I pumped to 3.5 bar and the rear to 3.0 bar. That was only to ensure I did not write a tyre and a rim off in the pothole littered roads around South Africa. Those pressures ensured rapid centre wear and a life of only about 20,000km, but it was preferred to regularly writing off brand new tyres and fixing the mags when hitting even the smaller potholes....
On all these other vehicles, I have always had the tyres wear evenly, never where the shoulders or centres wore faster than the rest of the tyre.
Of course, when loaded, I run totally different pressures, maybe 2.5 bar in the rear (never more) and 2.2 or 2.3 bar on the front axle. Even the off-road trailer, I mostly run at 2.0 bar. On normal dirt roads (mainly travelled when loaded for a off-road trip) I would run the rears at 1.8 bar and the fronts at 1.6 bar and on sandy tracks in the Kalahari and Botswana parks, front at 1.0 bar and 1.2 at the rear. When I did Faces of the Namib with the GQ, I ran those 33's at 0.8 bar all around, but I did manage to de-bead one of them on that trip (5 days between Solitaire and the coast, ending in Walvisbaai).
Has thanked: 244 times
Would 3bar also be recommended for 31x10.5’s?
Was thinking to try 2.6bar first..
Take a bit of chalk and make tread white drive 100m look when it start to not come off sides then drop 0.3bar
offroadbiker wrote: 12 Mar 2019 09:29 3 bar on tar.
Watse 33" bande het jy op: 285/75r16 of 33x12.5r15?
Want dit wil vir my voorkom maksimum band druk vir 33x12.5r15 is 35psi(2.4bar)...
https://tiresize.com/tires/Cooper/Disco ... T-MAXX.htm
33x12.5x15
General Grabbers
Return to “14. Rims & Tyres”
