2H to 4H While driving...Is it really possible?
- ra_01
- Full Name: Rahul
- Nickname: Rahul
- Current 4x4: Patrol 4.8 2016
- Has thanked: 23 times
- Been thanked: 60 times
Re: 2H to 4H While driving...Is it really possible?
Yes I’ve seen that video when I was doing my research before I purchased my first Patrol. He didn’t mention anything about locking the hub if you want to switch to 4H while doing 80km/h. May be it’s an assumption that hubs must be locked!
Rahul
Current Straight 6
Rahul
Current Straight 6
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 719 times
The owners manual also says nothing about locking the hubs. However, when I first tried to shift from 2H to 4H with hubs on auto, one could hear the grating of the splines. Also, the shifting was difficult (as you also have noticed). Further reading on the matter indicated (to me at least) that shifting without the hubs locked could cause issues. Since there is really no difference in driving the vehicle in 2H with the front hubs locked, I prefer not to take chances, and I lock my hubs on the occasions where it seems as if I may need to shift between the two on the move.
- ra_01
- Full Name: Rahul
- Nickname: Rahul
Ian, I’ve also noticed this in my recent trip. Tried shifting to 4H while driving when the hubs are on auto and I could hear a noise..so didn’t take any chances.
It’s funny the manual also didn’t mention anything about locking the hub.
Rahul
Current Straight 6
Rahul
Current Straight 6
- ra_01
- Full Name: Rahul
- Nickname: Rahul
Saw the video again. If hubs are locked then we could shift to 4H at upto 80km/h, and 40 km/h when on auto.
But that’s on manual gearbox.
https://youtu.be/n6wt6d_xvrA
Rahul
Current Straight 6
Rahul
Current Straight 6
- Full Name: Jaco Richter
- Nickname: Jacor
- Current 4x4: Jeep Grand Cherokee 2012 V6 CRD Overland
- Been thanked: 16 times
A slight variation to the posted question.
I have a Lock-rite auto front locker. Can I still drive in 2h with the hubs locked and shift to 4h when needed?
Sent from my VOG-L09 using Tapatalk
- Full Name: Reenen Kritzinger
- Nickname: Reenen
- Home Town: Greyton
- Current 4x4: SFA Hardbody
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
88 Isuzu RD28 Nissan
1978 300D Merc RD28 Nissan - Home Language: Afrikaans
- Has thanked: 4 times
- Been thanked: 126 times
Die locker sal geen verskil maak nieJacor wrote:A slight variation to the posted question.
- Nickname: Jacor
Dankie Reenen.
- davidvdm
- Full Name: David vd Merwe
- Nickname: David - Hillbilly
- Home Town: West Coast
- Been thanked: 48 times
It's all about having the front and rear propshaft speeds matched inside the TC. Auto hubs will not have this happening as it disengages the front drive train. Manual Hubs, or Auto hubs set to the locked position will keep the front drievtrain engaged, and the propshafts spinning. My Sani TC can do it, and the Sani now with the Safari TC does it with hubs locked.
And it can be done virtually at any speed. I have noticed on a gravel road, at any speed while a having a fair amount of throttle applied, going from 2H to 4H does not want to go. The rear wheels are actually spinning on the roar surface compared to the front wheels that are just being pushed along. The Sani TC would offer resistance, but not make any noises. The Safari TC actually makes a bit a noise as it tries to engage the splines that are not running matched speeds. Get off the loud pedal and just coast, and the TC will go into 4H. Both the Sani TC and the Safari TC have done this at speeds of over 120km/h.
I drive permanently with the Hubs locked, as I am only on tar roads for about 40km every two weeks. I shift between 2H and 4H a few times a day. The TC will even have a problem shifting to 4H if you are executing a turn, as the front drivetrain will be covering a longer distance compared to the rear, causing mismatched speed of propshaft in the TC. I see guys here with auto Hubs have the same problem over and over, where they have to stop to engage 4H. Fairly irritating for us that have the capability of doing this on the fly.
One guy even does a reverse back and forward to engage and disengage. Frighting experience when are you able to just drop back to 2H on the fly and ready to boot the thing, and this guy stops dead, and reverses back at you a few meters before he can carry on.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
