Patrol 4.2D Motorhome conversion - PRICE DROP!
DMH
Full Name: Tejan Pillay
Nickname: Tej
Home Town: durban
Current 4x4: 95 Patrol SGL 4.2D,
02 Hardbody 3L TD
Home Language: english
Has thanked: 15 times
Re: Nissan Patrol 4.2D Motorhome conversion
Post by DMH »
Cheers for the insights chaps - especially all your calculations Ricster!
OK so I put in a bid of a R99k - and I got it. I have till next Wednesday to make payment else the sale is cancelled - however I may be able to get a few more days leeway.
Now many here have said that this is too high a price - would you still say so in light of Ricster's musings?
While I daydream about a Cape to Cairo (or in my case maybe a Durbs to Dakar or Djibouti) trip in it, that's not going to happen anytime soon - and I still have my GQ to pimp up for that mission oneday!
So would anyone be interested in it? Please let me know soonest.
Here's more details that I've uncovered:
I called Motorhome World - they couldn't give me an exact price on the conversion (due to the design and engineering costs, etc) but said it was definitely over R200k. I asked if they'd do a conversion to a camper - they don't but referred me to AC Motorhomes in CapeTown too - they're getting back to me with options & pricing.
In chatting further to the drivers:
They said that it had been overheating for the last 2 years - only on the freeway usually up long hills - the needle would climb to nearly the top, but drop after the hill.
They took it to Nissan several times, and had the radiator cleaned then changed, but they never resolved the problem.
The day it overheated, the driver noticed white smoke coming out the exhaust, but didn't see the temp needle climb so wasn't too concerned - he drove it to a mechanic who confirmed that coolant had leaked - probably head gasket. They stripped the head and gave Eskom the quote - a whopping 97 grand. I spoke to him at length earlier and he said he would happily revise the quote now that he knows it's in private hands :rolling: He said they'd need to x-ray the block to confirm if any damage there but didn't appear to be from a visual inspection.
The suspension was strengthened a year ago (more leaf springs, and taller springs) and that's when they noticed a hairline crack on the chassis which was repaired (apparently a common problem with Eskom Patrols - that and overheating - unfortunately Patrol's don't have a good name here. Our Landcruisers seem to fare better, but they're the 4.5 petrols only - perhaps diesels would share the same fate as our Trolls)
They get about 6-6.5km/l - dual tanks
Clutch replaced @ 110k.
Gearbox fine. 4x4 operational. Hubs work/ suspension fine.
Invertor (for 220V plugs) - stopped working.
Dual batteries in camper seem to be dead
Compressor still in
rearview Camera - head unit faulty
No water tank
So that's what I've got thus far - I'm sure plenty of history could be sourced from Nissan itself - and I may be able to get other invoices/etc from them - you're most welcome to speak to the drivers as well.
Do let me know if you'd be interested in such a vehicle or know of anyone who might - either as a camper, or utility vehicle.
Cheers!
Been thanked: 473 times
Congrats !!
For R99 000, I still think its a good deal for the camper and a 2009 model and a TD42Ti.
The motor, by the sounds of it has either burnt a hole through the piston, if its bellowing white smoke, as white smoke means means oil ( unburnt ) in my opinion. This ccan only be checked via a compression test or by removing the head.
There is a very good chance that the head is cracked, causing the overheating. When you open the motor, if you are lucky, It might just be worn rings and not a burnt hole in the piston. Then I would suggest a good clean out of all the water channels in the block to ensure there is proper coolant flow. Replace the head and gasket and head bolts, obviously ensuring that the sleeves and rings are in good condition, and you will be in for a whole lot less than a fully rebuilt engine from Michael. However ..... I would still look at spending the money with Michael and putting in a fresh rebuilt motor in and then you have basically a brand new beast
If there is no rush, and you do the rebuild yourself, well then you could save yourself a few rands too
Been thanked: 430 times
Well as many have said, this can be a very nice camper when completed :thumbup:
The engine is the only concern, its impossable to guess what needs to be done before everything is stripped and checked.
It might end up cheaper than the 65k which will be a bonus.
Keep us posted on whats cooking
DMH
Nickname: Tej
Home Town: durban
02 Hardbody 3L TD
Re: Patrol 4.2D Motorhome conversion - PRICE DROP!
Post by DMH »
See the update to my OP folks - price is now R70k!
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
What ever happened to this vehicle?
I think 70k is a good price?
