Patrol Death/Steering Wobble – Trouble Shooting & Fix
davejones
Full Name: David Jones
Nickname: David
Home Town: Lagos, Nigeria
Been thanked: 6 times
Re: Patrol Death/Steering Wobble – Trouble Shooting & Fix
Post by davejones »
after driving into a serious donga at Groenkloof Jongosi has developed the death wobble :sad:
thank goodness for this post - I will be parking Jongosi in the garage and begin the great mend.
I have already had some LUDICROUS quotes from a number or suspension / steering shops and am taking the mantra - you break it you fix it!
On the positive note - I was out at Groot Marico over the weekend, spent the day on the dirt roads between Groot Marico and Zeerust practising my recovery skills as they had had over 100mm of rain over Friday night / Saturday morning. Thinking of renaming Jongosi ; Imvubu which means hippo in zulu :biggrin:
good looking rear-end
An ox, but with balls !!!
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
Mind sound silly - check you rims, tires and wheel balancing first - make sure the tires run straight without bounce and that the finger thingy is used instead on the cone when they balance the wheels.
and then start work the list
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
JohnDough wrote:Mind sound silly - check you rims, tires and wheel balancing first - make sure the tires run straight without bounce and that the finger thingy is used instead on the cone when they balance the wheels.
I agree - especialy with all the mud on the inside of the rims - clean them out first.
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
davejones wrote:Thinking of renaming Jongosi ; Imvubu which means hippo in zulu :biggrin:
I'm afraid the name's already taken; my wife instantly named my Patrol"Imvubu" the moment she first saw it :lol: .
davejones
Nickname: David
Post by davejones »
Having sold it to the "father in law" he's assumed the responsibility of having the wobble fixed. Jongosi is with Boss Auto on Braam Fischer Drive in Randburg.
The fault was definitely pin pointed as the bushes being in pretty bad shape all around, with my knock at Groenkloof being sort of a last straw for the front suspension. He's having everything done and replaced, from panhard rod, tie ends, bushes, CV's, bearings the lot... the price something in the region of R24K :surprised: not a cheap excercise, but he's having everything replaced using OEM parts.
Johndough we did all the "simple" checks and everything came out okay.
I'm just pleased the family now has two Trolls !!!
christolemmer
Junior Member
Junior Member
Full Name: Christo lemmer
Nickname: Christo
Home Town: Menlyn Pretoria
Current 4x4: Nissan Patrol 4.5 gl
Has thanked: 10 times
Post by christolemmer »
Hi Ross
Sit met die selfde probleem, nadat ek jou post gelees het, het ek gesien die patrol se panhard bushes is kis het nuwes bestel. Sal intussen ook die wielbearing nagaan en seker maak die res van die balljoints is reg. ek is nou positief ek sal die wobble oplos.
Groete Christo
[quote="davejones"]after driving into a serious donga at Groenkloof Jongosi has developed the death wobble :sad:
Hi Dave -- Yipp, imvubu is taken .. But can oompie suggest INYATI for a name [Zulu for The Buffalo] .. [even Elephant stands back for a Buff :oldtimer: :thumbup: :salute:
Wynvat
Full Name: Gerhard van Rhyn
Nickname: Wynvat
Post by Wynvat »
My Patrol is now 9 years and 2 months old, and has done 172 500km.
It has now suddenly developed The Wobble of Death. We had the third occurrence this weekend. I have experienced that it happens at any speed from 80km/h upwards. The slightest imperfection on the road surface could suddenly, unexpectedly (it does not happen often, like the Perfect Storm) and violently throw the front wheels into a wobble of imminent death, measurable on the Richter scale. It feels like the car is going to self destruct, like a chopper that lost a rotor blade in mid flight. I had to wash my youngest one's breakfast from the rear window afterwards. We were on our way to a wedding in the Free state, and my teenage daughter had to change undies at the church :clap: Point is, it has to be sorted out... :oldtimer:
It is not possible to accelerate out of the wobble. Taking my foot off the accelerator also does not help. The only way out is to hold the steering wheel very tight and straight, and brake forcefully. Applying the brakes forcefully feels like it not only serves to lower speed, but also to positively kill the wobble.
I have read a lot on the subject and everything supports what is said in the first posts.
My question: who would you recommend in Pretoria that is dependable and knowledgeable and will go through the trial and error process to sort out my beloved friend?
Hello en wekom terug ry gereeld hier verby jou....
Mater vat hom na barend toe by auto wiel centorion wes daar waar sirkel bande was ....daarna maak n draai by Graham toe om bearing tension te check... :thumbup:
Wynvat
Nickname: Wynvat
Post by Wynvat »
Baie dankie Tinus, ek gaan so maak.
