4x4 propshaft
AdrianPowrie
Full Name: Adrian Powrie
Nickname: AdrianPowrie
Current 4x4: 2003 4.8 auto
Nissan 3.0 SE 2x4
Willy's Jeep/toyota...
Has thanked: 20 times
Been thanked: 13 times
Re: 4x4 propshaft
Post by AdrianPowrie »
Guys, as Pieter says...
We have had bad experiences on our commercial fleet with any type of lube on the prop shaft joints...
Grease the universals but leave the mating surfaces dry.
If any corrosion happens, it just aid's in keeping it all together.
Adrian
2003 4.8
Front bashplate (PC)
Transfer case skid plate (PC)
Re: 4x4 propshaft
I know that my Boet's company put "Formagasket" on the faces...
Rhett
Nickname: Rhett
Home Town: Heidelberg
Has thanked: 163 times
Been thanked: 78 times
Re: 4x4 propshaft
Post by Rhett »
Interesting points being made, I am very uneducated with propshafts, so this is helpful.
David, do you know why the spring washers were bad news? I recently just put some on a propshaft but included Pratlok 6 - 10 grade, which is medium strength thread lock I think.If the spring washers have a chance to fail, I'd rather take them out ASAP.
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Re: 4x4 propshaft
Post by davidvdm »
Rhett, I must be honest and say that I can't remember, but I think it had something to do with the way it digs into the surfaces and the possibility of it splitting open and leaving the bolt/nut with no tension and thus allows it to loosen up. But this might be me lending my ears out. In all my years, I have never come across this story before, and I still have all my split washers in place on my propshafts.
I just mentioned it in the hope that an expert, like Mr Conan, might have some comment for us.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
Has thanked: 1135 times
Been thanked: 1044 times
Re: 4x4 propshaft
I only comment when I have specefic knowledge (or a very strong opinion), which, in this case, I don't.
My only recommendation is to use whatever the manufacturer uses. They usually do things for a reason.
Re: 4x4 propshaft
I dont put anything between the two joints. This is one of those items where it really does not matter if any moisture comes in as you rairly have to remove the propshaft. Someone also mentioned it sort of corrodes over time whick is not a bad thing.....I agree and it can sometimes require some hammer action to seperate the two
If you ever need bolts and nuts, just order from the dealers as the bolt places dont really always know what is going on
