Misfiring on one cylinder
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Re: Misfiring on one cylinder
Post by Wilkie »
BaasWiets wrote: 31 Mar 2019 07:08 Morning has the problem been solved my 4.5 also started doing this after a couple of km it gets itself right.
Wiets does yours only misfire on start up and then goes away after a while...???? if thats the case then you have a wet sparkplug which clears up once temp has increased
BaasWiets
Full Name: Wietsche Swanepoel
Nickname: Wiets
Home Town: Delmas
Current 4x4: Nissan Hardbody
Nissan Patrol
Been thanked: 12 times
Post by BaasWiets »
Nee hy is partykeer reg het nuwe pomp ingesit, plugs, fuel filter, als uitmekaar gehaal en skoon geblaas met air die ding sal partykeer mis en dan is hy reg en dan weer so maak het n pressure gauge opgesit en die pomp lewer so 2.6 tot 3bar weeti wat met die ding aangaan nie het al n helse lot geld op die ding gespandeer en niks werk nie. Dit is besig om my die mo#r in te maak. Ek moet volgende week kruger toe gaan vir drie weke en wil my karrevaan met hom sleep dit is waarvoor hy gekoop is maar nou wil hy nie saam speel nie. Sal more weer krap by die werk.
pdasilva
Full Name: Paulo
Nickname: da Silva
Home Town: Kempton Park , Gauteng.
Current 4x4: Nissan Patrol 4.8grx
Suzuki Sidekick 1.6
Been thanked: 4 times
Post by pdasilva »
I had a similar problem on my safari.
Turned out to be a torn fuel pipe close to the fuel rail sucking in air.
Users browsing this forum: Google [Bot] and 2 guests
