4.8 GRX Radiator Failure
- Been thanked: 473 times
Re: 4.8 GRX Radiator Failure
Definitively a good idea to drain and change. I just did mine after 100 000Km. The coolant still looked very good ( nice clear blue tinted water came out ). I replaced with the antifreeze I originally got from Silvertons Radiators ( Nissan original price is ridiculous ). I bled the system properly and noticed a few mm difference on the dash temp gauge.Wilkie wrote:Just a thought...who as ever changed the anti freeze on a regular basis.......???
There has to be a reason why there are so many Patrols pop their radiators..does the antifreeze changes its character after a certain age and generate more steam or or or ???
Just putting it out there..
IMPORTANT !!!!!!...... stick to the mixing instructions !!!!! Rather slightly over dilute than under dilute as the coolant, if too strong, can have very negative effects on the metal in the motor !!
My system with the bigger radiator takes close on 13-14L of water. The coolant I use is a 50/50 mix ratio, but only used 6 bottles so am a little under the 50/50 mix.
- Been thanked: 430 times
The original Nissan antifreeze states on the bottle to mix it 30% antifreeze with 70% tap water. they are very strong and probably one of the best on the market.
But yes as Cedric mentioned.....they are MADLY priced at Nissan and you really find it hard to swipe your card on the purchase. So on a system flush, you need about 4,5L so 5L is fine but it is going to set you back almost R700
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 189 times
- Been thanked: 270 times
Yep, dropped R700 in November for new anti freeze at Nissan just before the Rust de Winter trip, now I would like to take the radiator out for a clean but don't want to spend that again....
I cannot see why not. Coolant is too expensive to just discard and if you filter out any dirt that came into the bucket your antifreeze should be fine. I have done this before on my own and had no problems.ricster wrote: I think I'm going to make a plan to somehow drain the water out into a container, change the hoses and then filter the coolant before putting it back.
- Junior Member
- Full Name: Van Pletzen
- Nickname: Japie
- Current 4x4: Nissan Patrol GRX
- Been thanked: 2 times
Got a radiator from Graham for R4500.00 and a viscous fan from Imperial Nissan Menlyn for R4300.00. Patrol fixed up again. Received very good service from Riaan at Imperial Nissan Menlyn. Had no problem installing the radiator not sourced from them. Thank you to forum members for the interest and help.
Japie van Pletzen.
Japie van Pletzen.
- biggles
- Full Name: Steven
- Nickname: Steve
- Home Town: Durbanville
- Has thanked: 21 times
Did you not get a temperature warning before it popped?
