6mm Wheel Spacers - Round 4
Re: 6mm Wheel Spacers - Round 4
The spacers we made up are anodized so rust isn't an issue at all.Carel wrote:Would it be a good idea to have 1 spacer in the toolkit for when you need to borrow a spare wheel from a non Patrol mate? I think it has been mentioned before that the spacer will also help to clear the ridge on Patrol hubs.
SJC - Why 10mm? you will definitively need longer studs then.
- Full Name: Fanus
- Has thanked: 246 times
- Been thanked: 219 times
It is for my bakkie's rear wheels, want to add them to the 30mm bolt on spacers/adaptors, which got long studs.
I'll speak to Greg (juice) but I know we needed to get a batch made up to make it cost effective.....
- Newbie
- Full Name: Marnus Els
- Nickname: Bosvark
- Home Town: Knysna
- Current 4x4: Nissan Patrol 4.2TD Pickup
Kan jy my asb skakel aangaande die spacers?
Kan jy ook my help met n stel 35mm vir agter en n stel 6mm vir voor op my GU Y61 Pickup?
Bosvark.. Marnus
0714795838
Bosvark.. Marnus
0714795838
- FB_IMG_1479653403707.jpg (124.59 KiB) Viewed 4411 times
- Full Name: Fanus
Ek het sommer 30mm spacers by 4x4direct gekry om agter op my bakkie te sit: http://www.4x4direct.co.za/wheel-spacer ... atrol.htmlMarnus wrote:Kan jy my asb skakel aangaande die spacers?
Bosvark.. Marnus
0714795838
Hi Gents -- I baught a set with the previous run .. BUT my rims' metal is too thick so I cannot put it on iNyathi -- not enough stud left to grip than.
So the set is up for grabs at what I paid for them.
Available immediately.
Sorry Ricster if i hi-jack your fred here
No problem Oom mac. If they don't work for your Patrol better to pass them on than them sitting in the garage collecting dust. We never made a profit out of these spacers, we sold them as what they cost us to manufacture.
Marnus, unfortunately the thickest spacers are only 6mm. I did this cause they fit on my Patrol. When bigger spacers are involved, there is a lot more engineering involved. We don't have any more of these as we made them up as a batch. I would suggest grabbing them from Oom Mac ( Kagiso ). Just ensure you have sufficient thread on the wheel studs to ensure a good fit.
- Full Name: Fanus
Ek soek nog 2 spacers. Weet nie of marnus die ander 2 soek nie?Kagiso II wrote:Hi Gents -- I baught a set with the previous run .. BUT my rims' metal is too thick so I cannot put it on iNyathi -- not enough stud left to grip than.
Sorry Ricster if i hi-jack your fred here![]()
Marnus wrote: Kan jy ook my help met n stel 35mm vir agter en n stel 6mm vir voor op my GU Y61 Pickup?
Bosvark.. Marnus
0714795838
OuuuuuuuuuuKyyyyyyyyyyyyyyyyy .. Die Oompie is back from Botswana Outreach [got home Sat 24th late ]
Inyathi still goes. still gets hot at times.
Had a most amazing Outreach in all aspectys
O ja .. The spacers are still available ... All 4 of them. as new as when it came to me from Rictster.. die nommer is 084 084 8755
