Opinion on feul "Adventure tank"
- Full Name: graham robertson
- Nickname: graham1
- Home Town: Harties
- Has thanked: 9 times
- Been thanked: 100 times
Re: Opinion on feul "Adventure tank"
Its a long shot - but what about those jerry can holders that fit on the sides of a Defender?
They hang on the roof gutter and then the bottom of them bolt through the rear fender.
Not sure if they'll fit, and you'll need to drill through your fender, and I see you have gullwing doors where the rear windows were, but, if you don't need to open these doors it could work.
This way you have the cans outside, as well as helping with the centre of gravity.
Front Runner makes them.
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 193 times
- Been thanked: 275 times
Wont work, the Gullwings give access to my kitchen and the "bar" so will definitely be using them on a daily basis. and not planning on drilling holes into my rear doors to have it fitted there as we are only 2 people in the front.
Only solution is in the vehicle.....
- Full Name: Ian Temperley
- Been thanked: 92 times
And hope a taxi does not drive into the back off you!!! I have found an advantage with diesel it does not go boom when the taxi go's into the back of you
- Has thanked: 61 times
- Been thanked: 257 times
Graham, that is a Defender thing. It does not really work for other vehicles.graham1 wrote:Its a long shot - but what about those jerry can holders that fit on the sides of a Defender?
For one thing, no-one wants to buy your car having adding such brackets to the body of the car, unless of course it is a Defender.
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Has thanked: 3 times
- Been thanked: 26 times
Search around and see if you can find a fuel bladder. There used to be 20lt units that fitted in the foot well behind the seat.
As for more weight, please be careful. The shocks and coils in the patrol are competition units and coils are progressive . The rear coils already have 30 mm spacers to level it.
- offroadbiker
- Nickname: ORB
I got hold of a 30-35L sub tank from a GU with its bash plate, and it seems to be a perfect fit underneath the GQ.
So now it is the planning on getting it fitted, connected and a pump with switch to pump the diesel to the main tank when required.
So this gives me 150L of fuel, never have gotten worse consumption than 5km/l so reach distance of 750km worst case scenario, 1050km best case and an average of 900km.
I am sure this should suffice for almost all my trips and no more Jerry cans
- offroadbiker
- Nickname: ORB
I recon the 30L should not make that big a difference as it is way less than an additional 2 persons in the back??Grant wrote:Dirk
Do you know the weight rating of the coils?
- Been thanked: 432 times
Dirk, is jerry cans regtig so bad?
Ek het nog nie eintlik met myne getravil nie, maar klink nie vir my so erg om twee kanne saam te ry nie?
