Terrain Tamer Parts
Re: Terrain Tamer Parts
Very good to know!
Please could we get a catalogue of what would possibly be available?
Good luck man!
Good luck man!
- Marino4x4
- Nickname: Marino4x4
- Home Town: Bloemfontein
- Current 4x4: Nissan Patrol
- Has thanked: 17 times
- Been thanked: 87 times
Hi
At the end I will have a look at importing most of the Terrain Tamer Parts.
http://www.terraintamer.com/sa/4wd-products
- Been thanked: 473 times
I'd be interested in a price for 6 new injectors. I see the TD42 and TD42T use the same injector
Nissan Patrol GU 1998 on TD42 TTIKGR4
Nissan Patrol GU 1998 on TD42T TTIKGR4
and front and rear brake pads
Patrol GU 10/1997- Front DB1361TT
Patrol GU 10/1997- Rear DB1148TT
- Been thanked: 430 times
Cedric, just out of interest, why do you want new injectors?
Are you sceptic on recone injectors?
Are those brake pad numbers the Ferrodo numbers of Nissan numbers?
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
Patrol GU 10/1997- Rear DB1148TT[/quote]
Tricster you don't have a pricing on those brake pads ?
Michael, I last had the injectors replaced ( not sure if they were recon or new - SAC Centurion did them a few years back ) for R425 each, and a few months back I picked up some bad diesel and my diesel filter was a bit old and I also hadn't checked the water level in it for way too long too. The result was that I landed up with a stutter when I floored it. I think under full load I was sucking a mix of diesel and water. I don't know if this could damage the very basic simple mechanical injectors we have in the TD42, but after changing the diesel filter the motor is running fine. I was/am just wondering if the spray pattern could be compromised now.
I was more curious as to the price per injector from Aus. vs getting it done here art Bosch
Tricster you don't have a pricing on those brake pads ?Wilkie wrote:and front and rear brake pads
hahaha.... not me bringing this stuff in bud !!
Ok makes sense, mine sometimes gives a puff of smoke just like a cylinder that misfires except it doesnt misfire which could point to a sticky injector. Also the other day after my Patrol has been standing for almost two weeks had a misfire on one cylinder for about 3 seconds before it ran like normal which could point to a dripping/leaking injector....... so I also have some concern that my injectors are not all that well.ricster wrote:Michael, I last had the injectors replaced ( not sure if they were recon or new - SAC Centurion did them a few years back ) for R425 each, and a few months back I picked up some bad diesel and my diesel filter was a bit old and I also hadn't checked the water level in it for way too long too. The result was that I landed up with a stutter when I floored it. I think under full load I was sucking a mix of diesel and water. I don't know if this could damage the very basic simple mechanical injectors we have in the TD42, but after changing the diesel filter the motor is running fine. I was/am just wondering if the spray pattern could be compromised now.
It was only this one time ever that it did this, but I am not loving it
I don't think the water can damage our injectors really, only the common rail ones must stay away from water
- Nickname: Wilkie
Michael...doen jou self n groot guns en laat daai injectors toets ,,,,,daai misfire en wit rookies is n groot waarskuwing vir n grenaad was se safety pin wat klaar ont trek is
betaal eerder nou bietjie geld
Dankie Errol, ek wil dit ook veilig speel en seker maak.
Ek het darem die EGT monitor so sal sien as n injector fail
