Patrol Recovery !!
Re: Patrol Recovery !!
Where are you going I will be at paindaine injambane area from 26 till the 10th of jan
CarloG
Full Name: Carlo Gonzaga
Nickname: Carlog
Home Town: Johannesburg/Midrand
Current 4x4: Nissan Patrol 4.8GRX 2005
Nissan Patrol 4.8 GRX 2010 (Retired)
Hyuandai Terracan 3.6L (Retired)
Home Language: Engels
Has thanked: 7 times
Been thanked: 12 times
Post by CarloG »
Tinus lotz wrote:Where are you going I will be at paindaine injambane area from 26 till the 10th of jan
i'll be at Sunset Beach a little after Xai Xai - i'm testing out my Conqueror Companion for the first time - from 27 Dec to 8 Jan. Which lodge are you staying at?
'05 Patrol 4.8L GRX
'13 Conqueror Companion
Specialsied Stumpjumper. Munga Trainee
JHB to London '07, 16000km, 39 days, by Bike
90days camping - JHB to Nairobi and back - 2014
"We travel not to escape life but for life not to escape us"
At paindane about 220km after xia xia very nice part of moz
Give me a call mabe we can meet up some where there pm me your no
OEBIE
Junior Member
Junior Member
Full Name: SOULBY KITCHING JACKSON
Nickname: OEBIE
Home Town: KIMBERLEY
Current 4x4: PATROL GRX 4.8
Post by OEBIE »
Hi! In 2013 there was mention of "Peter's recovery points." What is the best way to fit 2 recovery points up front? I thought I might just buy another hook and fit it to the left front. May be that hook is just a towing hook and not a recovery point - not strong enough to yank a Patrol out of a hole. :helpsign:
I think the issue with a second recovery hook up front on the other side is that, whilst the holes are there in the chassis, they're not threaded. Meaning one cannot just bolt in the new hook. Peter's recovery points replace the recovery hook using the standard threaded bolt holes. And he does provide rivnuts to insert into the blank holes on the chassis for the other side.
Yip, I have 2 of Peters recovery hooks on my Patrol. I like them loads !!!
The drivers side if I recall correctly simply bolts on using the existing 3 bolts ( or was it 2... can't remember), the other side has the holes but no thread. Rivnuts work great here, BUT I wouldn't use the rivnut recovery point on any angled recovery. The proper bolted one I think will be fine as the bolts go through the full thickness of the chassis rail. The rivnut recovery point is perfect for the safety lanyard or a straight recovery with no jerking.... just my opinion. Chat with Peter Connan about them too.
Has thanked: 1135 times
Been thanked: 1046 times
Soulby, the recovery points on the 4.8 are different from those of the earlier cars. Oh, and they are recovery points. Plenty strong. I have seen a bent one, but it took some seriojs abuse and the bend was in an area that doesn't in my opinion cause a risk.
I do not offer recovery points for tbe 4.8 because I can't do a stronger point than the factory one at the price you can buy it from Nissan (and I am sure you could get them cheaper from Partsouq or similar).
The good news is that on the 4.8, the attachment points already have captive nuts installed too. So all you need to get are an extra recovery point and a pair of longer bolts. M14 x 1.5 thread, but I can't remember how long. Pretty sure 50mm will be a bit longer than necessary without being too long to fit.
I also think the Njssan part number for the recovery point is mentioned on this forum somewhere...
Peter Connan wrote: 23 May 2022 20:39 ...
From PartSouq on a 2003 4.8, the part number is : 51110VC205 (HOOK ASSY-FRONT).
Edit: The thread you are referring to is : https://patrol4x4.co.za/viewtopic.php?p=61432#p61432 Seems as if they quoted Fanus R610 for one in 2015. That is not a bad price. I am sure David will also have...
bruce_k
Full Name: Bruce Killerby
Nickname: Killa
Home Town: Cape Town
Has thanked: 38 times
Been thanked: 20 times
Post by bruce_k »
OEBIE wrote: 23 May 2022 12:09 Hi! In 2013 there was mention of "Peter's recovery points." What is the best way to fit 2 recovery points up front? I thought I might just buy another hook and fit it to the left front. May be that hook is just a towing hook and not a recovery point - not strong enough to yank a Patrol out of a hole. :helpsign:
Hi Oebie. I have an original tow hook for you for R300 + postage. Same as the one in the attached pic...
Every dog has his day!
2006 Patrol TD42T GL
