Bosal Tow Bar
Re: Bosal Tow Bar
I am under the impression there is a piece of wire already plmbed in for that purpose, but I could well be wrong.
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Re: Bosal Tow Bar
Post by Clem »
Thanks Peter. Hopefully someone else will chime in. :-)
Re: Bosal Tow Bar
I dont think you need to cut the harness....wires thould we where :think:
DawidT
Full Name: Dawid Taljaard
Nickname: Dawid
Home Town: Witbank
Nissan Patrol 4.2l GQ
Volkswagen Caravelle 4 Motion
2018 Toyota Landcruiser V8 DC
Has thanked: 5 times
Been thanked: 30 times
Re: Bosal Tow Bar
Post by DawidT »
Clem, I havea GRX with a Bosal towbar fitted. Will have a look at the wiring and let you know. I hooked / scraped my towbar a couple of times and it is still looking good, was also thinking of cutting the lower bottom part off to get it higher of the ground.
PC, do you think I need to replace the bolts at some time? :think:
Re: Bosal Tow Bar
I would strongly recommend replacing the bolts after a real snatch recovery.
Clem
Nickname: Clem
Re: Bosal Tow Bar
Post by Clem »
DawidT wrote:Clem, I havea GRX with a Bosal towbar fitted. Will have a look at the wiring and let you know.
Dawid, I would really appreciate that if you could. If you do find anything of interest, perhaps a picture would be helpful as well, if that is a possibility.
DawidT wrote:I hooked / scraped my towbar a couple of times and it is still looking good, was also thinking of cutting the lower bottom part off to get it higher of the ground.
To be honest, I do not anticipate often being in situations where it will scrape but my plan is to only both the thing on when I actually need to go or alternatively, to remove the thing when I plan to do "real" off road work.
Clem
Nickname: Clem
Re: Bosal Tow Bar
Post by Clem »
It turns out that, per the Australian websites, Nissan do make a plug-in trailer wiring harness for the GU series. I reckon that that option is probably better than slicing into the wiring harness.
Now the question is, which Nissan dealer has a switched on parts guy that is likely to be able to find the correct part number without too much drama? Any ideas?
Clem
DawidT
Nickname: Dawid
Home Town: Witbank
Re: Bosal Tow Bar
Post by DawidT »
Clem, speak to Adrean. He is the parts manager at Vredenburg Nissan. I used him to source parts for my GQ after Middelburg and Witbank Nissan said they can not help me. He got the parts and couriered it down to me. His e-mail adress is: parts.cfg1@lmgh.co.za
DawidT
Nickname: Dawid
Home Town: Witbank
Re: Bosal Tow Bar
Post by DawidT »
Look at the thread "Parts supplier" You will find his tel nr there.
Clem
Nickname: Clem
Re: Bosal Tow Bar
Post by Clem »
Thank you Dawid.
