Body Lift
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
Re: Body Lift
Het dit oorweeg, maar as dit te veel werk is sal ek dit liewers los...
- Russ Kellermann
- Has thanked: 8 times
Re: Body Lift
There's absolutely no benefit and no need to body lift a GU / Y61 - wheel arches big enough for 35's even with 1- 2" lift most will have zero scrub.
A GQ / Y60 could perhaps benefit from body lift but would be far more sense to simply 2" lift it, can run 35's off that alone.
Body lifts make zero sense to me regardless. Such a hassle to lift everything else too, rear bar, front bar, gear levers, steering issues, bla bla bla. and for zero improvement in flex, ground clearances, traction, or anything else for that matter.
just my humble opinion naturally...
- Full Name: James Craythorne
- Nickname: James
- Home Town: Cape Town North
- Current 4x4: 1999 Nissan Patrol 4.5 GSX
- Has thanked: 6 times
- Been thanked: 4 times
Re: Body Lift
Hi Russ,
Can't agree more, I spent the money lifting the 'BODY' and did some suspension lift 2-3".
But you know what the "ACTUAL GROUND CLEARANCE OF THE DIFF" was only lifted when I fitted 315/75/16 MUD's
With the body lift and exchange bumpers yes the approach angle, centre critical angle (going over ledges and edges) changed a bit and the departure angle also.
But going over rocks and deep mud and sand did not really make a difference, TYRE PRESSURE IS MORE IMPORTANT than lift!
I.M.H.O.
J
I.M.H.O.
J
- Full Name: SJC
Re: Body Lift
To revive this threat....
I know Tijmen did a body lift on his gq.
Who else?
For doing a 5cm lift what needs to be taken into consideration?
Any step by step guides out there?
I am considering a bodylift to create extra clearance for 33” tyres. Gq seems yo have not as much clearance as gu for bigger wheels..
Got tjm gold suspension in my gq, not sure of the lift and they might have sagged a bit over the years...
Body lift seems to be a cheaper alternative to replacing the suspension or am i wrong?
Who else?
- Full Name: Reenen Kritzinger
- Nickname: Reenen
- Home Town: Greyton
- Current 4x4: SFA Hardbody
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
88 Isuzu RD28 Nissan
1978 300D Merc RD28 Nissan - Home Language: Afrikaans
- Has thanked: 4 times
- Been thanked: 125 times
Re: Body Lift
As suspensie klaar is, help body lift niks. Jy gaan net bump stips tref.
Ek het my een isuzu 100mm gelig om n rd28 voor in te kry.
Ek het my een safari mq160 75mm body lift gelig om n tb42 in te kry tussen bonnet en diff.
Oor algemeen nie lief om te bodylift nie, maar soms het mens nie n keuse.
- Has thanked: 60 times
- Been thanked: 255 times
Re: Body Lift
Ek het my body lift op Skilpad verhoog.SJC wrote: ↑07 Nov 2021 20:17 To revive this threat....
Who else?
Hoofrede was om 4.8 se bokant in te laat pas onder die GQ bonnet.
Dis nie maklike job nie, en daar was skade op draad werk wat ek moes fix na die tyd.
In GQ se geval, ja gee meer wheel travel, afhangede van waar bumpstops reeds is, gegewe suspension setup.
Maar sal dit nie sommer andersins doen nie. Sal eerder net suspensie verhoog.
Dinge kan bietjie snaaks lyk, afhangende van jou bumpers en spasies tussen body en bumpers wat jou looks verander. Dan kan jy jou brackets op jou bumpers verander ens, ens.
As ek jy is, sal ek op ramp ry en kyk wat pla op maks flex, en dan eers kyk na potensiele suspensie oplossings, en body lift as tweede opsie.
