Thermostat and Radiator
namvicsafaris
Full Name: chris
Nickname: santie
Home Town: windhoek
Current 4x4: patrol
Home Language: english
Post by namvicsafaris » 06 Apr 2018 12:42
Hello guys
i have 3 2017 patrol wiht 3l turbo engine which i got re-biult into 10 seater safari vehicles. they have been running fine for about a year and now seems to start running hot or maybe its been like this from the start but guides never informed us.
Im looking for a heavy duty radiator to fit these vehicles, any advise will be greatly appreciated and also my mechanic has removed the thermostat and cut out the inside and then welded in a washer to reduce the hole, but now it seems its running to cold, at round 60-70 normal and 80-90 under load.
any advise will be appreciated.
cheers
Has thanked: 565 times
Been thanked: 295 times
Re: Thermostat and Radiator
Post by Tinus lotz » 06 Apr 2018 14:47
Hi there
Stick to the normal patrol radiator and rather fit a madman to keep it in one piece
Are the thermostat a double acting one or not?
namvicsafaris
Full Name: chris
Nickname: santie
Home Town: windhoek
Current 4x4: patrol
Post by namvicsafaris » 07 Apr 2018 12:43
the thermostat is the original from the manufacturer, so im not sure, any way to see that?
namvicsafaris
Full Name: chris
Nickname: santie
Home Town: windhoek
Current 4x4: patrol
Post by namvicsafaris » 07 Apr 2018 12:44
where would i buy a madman?
Post by Tinus lotz » 07 Apr 2018 13:14
Micheal can put it together for you what do you want to measure egt water level and water temp?
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Post by SJC » 07 Apr 2018 19:48
