4.8 Alternator upgrade.
Has thanked: 109 times
Post by hugejp » 07 Feb 2018 14:08
Has anyone upgraded their 4.8's alternator?
I believe that the factory unit is a 70amp?? Can anyone confirm please...
I really think 70amps is very weak, I've had way higher output units on mk1 golfs in the past.
Any idea on where to get replacement units, part numbers & prices??
:helpsign:
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 42 times
Re: 4.8 Alternator upgrade.
Post by David » 07 Feb 2018 14:36
Nope - the Hitachi LR1110-718 as fitted to the TB48 is 110A. The ZD30 has an 90A and I think the old RD28's had a 70A alternator
ARB Bullbar, TJM 2" Suspension, Snorkel, 285/70/17 BFG KO2's, 40L Engel, Nuvi 1410, TPMS, SatNav
Post by hugejp » 07 Feb 2018 14:43
:thumbup:
Thank you!
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Been thanked: 93 times
Post by Wilkie » 07 Feb 2018 15:35
there is a after market 110Amp R2000.00
Post by hugejp » 08 Feb 2018 06:31
Wilkie wrote:
07 Feb 2018 15:35
Errol, is daar nie 'n grooter opsie as 110A nie?
Rodney
Full Name: Rodney Smith
Nickname: Rodney
Home Town: Port Elizabeth
Current 4x4: 2013 3.0D GL
Post by Rodney » 08 Feb 2018 07:11
Somewhere I saw a post by someone who upgraded to AC DELCO 120 amp successfully. I am in PE and happened to notice several AC Delco alternatures on display at Willards Battery outlet in PE. Try Willards.
Post by hugejp » 08 Feb 2018 07:14
I have seen 120A upgrades on the Aussie forum, so to hear there may be something local is great!
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Been thanked: 74 times
Post by ChristoSlang » 12 Feb 2018 21:10
I've gone to a 140A Delco Remy, and someone else went to an even more potent Delco Remy after my upgrade...
Christo (the snake man)
SJBS
Full Name: Steve Barnard
Nickname: Steve
Home Town: Ellisras
Current 4x4: 99 Trol 4500 GRX
Range Rover
Terrano
Has thanked: 5 times
Post by SJBS » 22 Sep 2018 12:25
Wilkie wrote:
07 Feb 2018 15:35
Hi Wilkie,
Do you know where I can source a similar aftermarket alternator for the 4.5 petrol?
Has thanked: 258 times
Been thanked: 256 times
Post by ricster » 25 Sep 2018 08:00
JP, what do you want to run with such a big alternator? TV's and all sorts of monitoring devices?.....haha
I have a 90 or 100 Amp aftermarket alternator in the Iron Maiden, and never been short of power. If yours as a standard has a 110 Amp unit, then I'm sure that is more than sufficient to run everything and more in your 4.8.
The TD42 only has a 60 Amp Hitachi alternator..... so I figured that was a little too small, hence the upgrade to 90 or 100Amp
