ZD30 Black Smoke
Johann 1984
Full Name: Johann van der Spuy
Nickname: Johann 1984
Home Town: Kimberley
Current 4x4: 2013 Nissan Patrol 3.0 Tdi
Has thanked: 1 time
ZD30 Black Smoke
Post by Johann 1984 » 26 Jan 2018 15:13
Dear Guys,
I am the only driver of my vehicle, and thus never have a chance to really drive behind my own vehicle to see the exhaust fumes.
My vehicle does not smoke ever, except for one two scenarios:
1. If the vehicle labours to the point of almost stalling.
2. If the vehicle stalled (as in on an hectic obstacle) and is restarted.
We are at the coast and my wife and her sister took the Patrol to do some shopping after spending time at the beach. I took a lift with my father in law and was driving behind my own car. There was a steep incline hill to which the Patrol drove up with a stop street at the top. The intersecting road were very busy. I take it my wife had trouble pulling off at such an steep incline and I suspect she laboured the engine. It produced a very big cloud of big black smoke. I take it this is excess diesel that was not burned being spat out through the exchaust?
The vehicle does not smoke at all any other way on normal diving. Is this something serious that I should be concerned about or check out. I am very aware that zd30's are notorious for burning holes and cracks into pistons. Is this a sign of a burning piston and trouble on the horison?
Thanks for the info in advance
Johann
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Re: ZD30 Black Smoke
Post by JoshJ » 26 Jan 2018 15:23
No. Sounds pretty normal. Black smoke is good. White smoke is bad. :mytwocents:
Being alive is a Blessing!!
Joshua
IanT
Full Name: Ian Temperley
2003 4.2 TDI (Ubhejane)
Been thanked: 56 times
Post by IanT » 26 Jan 2018 15:58
Very easy solution to your problem!! Don't let your wife drive :rolling: :rolling:
But on a serious note, all diesels smoke like that, my brand new Disco 4 does it, just remember to shift down on steep/long hills and rather keep the revs up and therefor your EGT down
Have you got a madman fitted?
Stephen
Full Name: Stephen.Borstlap
Nickname: Stephen
Home Town: Vredenburg
Current 4x4: 2008 Nissan Patrol 3.0 GL
Home Language: english
Has thanked: 1 time
Post by Stephen » 26 Jan 2018 16:08
That is normal under heavy labour . It does this as there is unburnt fuel and the turbo has not really started working yet . Mine has also done it on occassion.
Johann 1984
Has thanked: 1 time
Post by Johann 1984 » 26 Jan 2018 16:15
Thanks Ian and Joshua,
I almost had a mini-stroke and heart attack simultaneously. Yes, I have a black box fitted.
I have a 105 000 km on the lorry and I fear that dreaded rebuild of 160k.
Warm Regards
Johann
Johann 1984
Has thanked: 1 time
Post by Johann 1984 » 26 Jan 2018 16:16
While were at it... What causes the black smoke cloud? Is it unburned diesel?
Johann 1984
Has thanked: 1 time
Post by Johann 1984 » 26 Jan 2018 16:17
Sorry Stephen,
Saw your answer a bit late and thanks!
Johann
Has thanked: 163 times
Been thanked: 276 times
Post by Michael » 26 Jan 2018 16:52
Black smoke at low rpm is very normal and can be seen in many new cars.
Black smoke is fuel that has been burnt, white smoke is unburnt fuel and is the dangerous one which can point to injectors or some other problem.
Has thanked: 112 times
Been thanked: 106 times
Post by offroadbiker » 29 Jan 2018 07:23
BLACK smoke don't meant its broke!!! DIESEL POWER :blonde:
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
Home Town: Kensington, Jhb
2011 2.5 Di Pathfinder LE
Home Language: Afr & Eng
Been thanked: 39 times
Post by mvcoller » 29 Jan 2018 10:10
Black smoke is unburnt fuel, both in Petrol and in diesel vehicles. Very noticeable on pull-away in diesel vehicles when you pump a lot of fuel on acceleration, as is done on pull-away. It is normal.
Grey smoke is burnt oil, normally an indication of worn valve stem seals on pull-away and if it is while driving at normal speeds, it is worn bores, or a broken ring.
White smoke could be brake fluid normally on a petrol vehicle where the Brake Booster is faulty and when trying to make a vacuum suck brake fluid through the suction pipe between the inlet manifold and the brake booster, into the inlet manifold, into the combustion chamber, where it burns with a while smoke out of the exhaust.
White "smoke" that dissipates very quickly is normally steam, indication that it is more than likely a blown head gasket between the combustion chamber and the water jacket. The gasket may still be OK between water and oil c\channels and will then not have water & oil mixed.
