Dash Cubby for 2000 Patrol
EFH
Full Name: Elmar Henning
Nickname: EFH
Home Town: Bloemfontein
Current 4x4: 2000 Nissan Patrol 4.2d GL
Home Language: Afrikaans / English
Post by EFH » 24 Jan 2018 08:47
Hi all,
I am looking for one of these that go under the radio. Anyone have one? Where can I look?
Burnco Replacement Bumper, Suspension Lift, Terrain Taimer 'erd
Home Town: Brits
Nissan Patrol 4.8 GRX
Has thanked: 189 times
Been thanked: 234 times
Re: Dash Cubby for 2000 Patrol
Post by iandvl » 24 Jan 2018 14:00
The ones for the Hardbodies / NP300s around 2008 identical. Which means you should be able to get one at any bakkie place. Not sure where you are from, but try One-Tonner spares in Pretoria.
Edit: I see you are in Bloemfontein. I have one lying around in the garage at home. You're welcome to it, if you can arrange a lift.
Has thanked: 292 times
Been thanked: 111 times
Post by Kagiso II » 24 Jan 2018 15:09
I also have a gaping hole BUT mine is ABOVE the radio? [iNyathi is a 2000 Y61, mos]
THANK YOU for the heads up on the Hard Body bit that fits there Thanx IAN
Home Town: Brits
Post by iandvl » 24 Jan 2018 19:28
Oom Mac,
The GU has two standard DIN slots(180×50mm). One for the radio, one for the cubby. Some people may have aftermarket head units in (ie: double DIN).
Edit: if it is a double DIN, there is only space for the head unit, and there is no space for a cubby.
In short: if the radio sits in the top slot, the cubby can fit underneath. And visa versa.
Edit: I have to reroute my antenna some time. I will start a thread about removing the GU centre bit about that, with pictures, when I do. It is very easy.
Has thanked: 113 times
Been thanked: 93 times
Post by hugejp » 25 Jan 2018 17:34
I also have a cubby in the garage...
But I am not sure if its for a GU, GQ or a Hardbody...
It came in box of spare parts.
I will post pics soonest
Post by hugejp » 25 Jan 2018 18:59
Here it is...
Home Town: Brits
Post by iandvl » 25 Jan 2018 19:45
JP,
That is very different from the circa 2000 GU cubby. Pretty much sure it would work anyware (the DIN standard), but the holes on the side may not align 100%. No idea what variant that is from... :think:
Post by hugejp » 25 Jan 2018 20:10
I have no idea...
It looks like a generic from an audio shop?
Home Town: Brits
Post by iandvl » 25 Jan 2018 20:44
No - I didn't mean generic, as from an audio shop. It looks very 'Nissan-esque' in terms of the design (ie: very similar to the prior photos posted on this thread - with the taper along the sides, as well as the top and bottom).
What I meant by generic, is that because it is a DIN standard mount, it would fit in any vehicle capable of taking a DIN radio (ie: virtually every vehicle out there). The only issue is that the bolts in the sides may not match up with the bolts in the dash.
In short: pretty sure it is a Nissan cubby. Pretty sure it is not a circa 2000 GU cubby.
Which means it is either a GQ cubby, or a facelift GU one. Perhaps someone can clarify ? :)
Home Town: Brits
Post by iandvl » 25 Jan 2018 20:47
On the same note: the OP is getting the cubby as pictured in is original post. It is boxed and packed here, and the courier will collect it tomorrow morning. :rolling:
