Heater / climate control
DanieG
Full Name: Danie Gerryts
Nickname: Danie
Home Town: Stilbaai
Current 4x4: 2013 Nissan Patrol 4.8 GRX A/T
2016 Ford Ranger 3.2TDCi 4x4 A/T Supercab
Has thanked: 19 times
Been thanked: 5 times
Post by DanieG » 01 Dec 2017 09:43
When driving on a trip, I find that the heater comes on for no reason, especially after stopping for a while, but also simply while driving. After a while it goes off (or at least partially), to come on again from time to time. It makes no difference if the climate control is switched to its coldest. It is extremely annoying, but I do not know who on earth will be able to find the fault.
Danie Gerryts
NSRI Station 31
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Has thanked: 7 times
Been thanked: 19 times
Re: Heater / climate control
Post by Bruin Beer » 01 Dec 2017 10:31
Danie,
You have to confirm this is the case.
If you have warm air from the engine bay area leaking through to the air collector area ( the ducting area just before your windscreen) it would mean you will be getting allot of warm air blowing into the car which could feel to you like the heating coming on.
A good test would be to by-pass the warm water to the heater and see if you still experience a similar effect.
That would 100% proof if it is the heating control acting up or just a matter of warm air leaking in.
Hope this is of some help.
Riaan
DanieG
Nickname: Danie
Home Town: Stilbaai
Post by DanieG » 01 Dec 2017 14:12
Hallo Riaan
Nee, die lug wat deur die normale ventilasie inkom, word net skielik warm asof die verwarmer aangesit word. As mens die lugreëling aansit, is dit beter, maar mens kan voel die verwarmer is ook aan. Na 'n tyd gaan die verwarmer dan weer af, mens kan dit duidelik voel. Dit is of die verwarmer vol aangeskakel word en dan later weer af (of ten minste kleiner).
Danie Gerryts
NSRI Station 31
Has thanked: 308 times
Been thanked: 381 times
Post by Peter Connan » 01 Dec 2017 21:51
In the Patrol, the heater matrix is always on, and the air reaching the interior is controlled by a series of solenoid-activated flaps/valves.
Sounds to me like one of these is misbehaving.
DanieG
Nickname: Danie
Home Town: Stilbaai
Post by DanieG » 02 Dec 2017 10:42
Now where do I find somebody with knowledge who will be able to fix it?
Danie Gerryts
NSRI Station 31
Has thanked: 113 times
Been thanked: 93 times
Post by hugejp » 02 Dec 2017 10:58
Is there not a fuse for the air system that can be pulled?
To cut power to the flaps to see if this stops the actuation?
DanieG
Nickname: Danie
Home Town: Stilbaai
Post by DanieG » 03 Dec 2017 10:21
My knowledge is quite limited. It seems as if a thin vacuum pipe leads to what I assume can be a heater valve or something in front of the fire wall.
Danie Gerryts
NSRI Station 31
