Steering shudder on braking
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 31 times
Been thanked: 28 times
Post by Clem » 28 Nov 2017 06:27
My 2013 GRX recently had an ARB b/bar with T/max fitted. This necessitated a simultaneous suspension upgrade with OME. 20mm front and 30mm back (back right corner only still needs a trim packer - about 15mm down compared to left back).
Car drives beautifully with the new springs. Yesterday on the M1 north and round through to Centurion though I noticed that it has a steering wheel shudder when braking firmly at fairly high speed - say a true 120k/h (130km/h on the clock). Far less (hardly noticeable) at 80km/h and nothing at 60km/h. So that tells me that its probably not a warped disc.
I'm wondering if it could be that the castor is just about neutral and as one brakes it pushes it into positive (or maybe more positive) or possibly insufficient toe-in (hasn't been checked in 45k km since the car was new). I suppose that the only way to be sure is to have it checked with one of those Hunter alignment machines?
Any thoughts?
Has thanked: 300 times
Been thanked: 369 times
Re: Steering shudder on braking
Post by Peter Connan » 28 Nov 2017 07:40
I doubt caster on it's own can cause a shudder, and suspect the problem is more likely related to tire wear or balance?
I would try rotating and seeing if that makes any difference.
Has thanked: 109 times
Post by hugejp » 28 Nov 2017 08:09
Have you by any chance changed brake pads recently??
I had a very similar experience when I fitted 4.5 pads by accident instead of 4.8 pads.
Exactly as you describe your symptoms.
Clem
Nickname: Clem
Post by Clem » 28 Nov 2017 08:27
Peter Connan wrote:
28 Nov 2017 07:40
Thank you Peter. I will check it out.
Clem
Nickname: Clem
Post by Clem » 28 Nov 2017 08:29
hugejp wrote:
28 Nov 2017 08:09
Thank you JP. No, there has been no change of the brake pads.
To be honest, I think it might just be that particular road surface. I don't know why but only on the road between Johannesburg and Pretoria/Centurion do I sometimes get a bit of steering wheel shake. Yet I can drive a thousand kilometres from here to the Eastern Cape without experiencing it once.
I think I will just monitor the situation for a while longer and see what develops. It's not a safety issue, at least not yet.
IanT
Full Name: Ian Temperley
2003 4.2 TDI (Ubhejane)
Been thanked: 56 times
Post by IanT » 28 Nov 2017 09:01
Clem, when are we going to see a picture of this beast of yours with all its new hardware????
Clem
Nickname: Clem
Post by Clem » 28 Nov 2017 09:21
There's a picture of its *koff* in the checkstrap thread! 😉
Will make a plsn!
IanT
Post by IanT » 28 Nov 2017 09:40
Clem, looking at those photos of your Patrol in "barn door" post is like reading scope magazine in the old days, you can only see bits and pieces :rolling: :rolling: We want to see everything :blonde: :blonde:
Has thanked: 259 times
Been thanked: 256 times
Post by ricster » 28 Nov 2017 11:14
:rolling: :rolling: :rolling: .... Ian... you took the words right out of my mouth.... :rolling: :rolling:
Has thanked: 565 times
Been thanked: 295 times
Post by Tinus lotz » 28 Nov 2017 11:19
Get some brake cleaner in can spay the disks and try again it sorted my problem out
