Y61 wheel bearing spanners
Has thanked: 269 times
Been thanked: 100 times
Re: Y61 hub spanners
Post by Kagiso II » 07 Nov 2017 17:17
Ooooooo -- nou weet ik ook.[ek het so iets vermoed maar ek leen gewoonlik Tinus se wiel spennir daarvoor :biggrin: :-) ]
Has thanked: 244 times
Been thanked: 328 times
Post by Peter Connan » 07 Nov 2017 17:44
biggles wrote:
07 Nov 2017 15:13
Kagiso II wrote:
07 Nov 2017 12:15
:redface: :redface: :doh: :doh: :rolleyes: :rolleyes: :rolleyes: :oldtimer: :oldtimer: -- Nou slaat oompie n BLANK .. wat is n HUB spanner? wat doen hy?
Saves you having to get the wheel spanner out to change the hub from auto to lock. Small and compact enough to sit in the glovebox.
Negative. This is for torquing up the wheel bearings! Sorry. Will change the thread name and first post.
Who'se mind does this change?
Home Town: Brits
Nissan Patrol 4.8 GRX
Nissan Hardbody 2.4 4x4 D/C
Has thanked: 142 times
Been thanked: 173 times
Post by iandvl » 07 Nov 2017 17:47
Peter Connan wrote:
07 Nov 2017 17:44
Mine in. One please (if there are still available).
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
Home Town: Kensington, Jhb
2011 2.5 Di Pathfinder LE
Home Language: Afr & Eng
Been thanked: 35 times
Post by mvcoller » 07 Nov 2017 19:49
When I had my Safari (Poeliesvehn) I took a geyser spanner (for removing the element, it think it is 46mm), cut it open on all 8 corners and then bent it open a bit. After that I welded a strp around it to make it the correct size for the front w/b on the front wheels. I think it's size is 52mm
Maybe I should get the correct one from you Peter. Please put my name on the list, I will fetch it at your place in Kempton when its ready.
You can sms or whatsapp me on "oh ate three 29six fifty seven twenty"
Current 4x4: PATROL COLLECTION
2004 4.8 GRX "Tinkerbell"
Has thanked: 101 times
Been thanked: 71 times
Post by hugejp » 07 Nov 2017 20:28
Peter Connan wrote:
07 Nov 2017 17:44
biggles wrote:
07 Nov 2017 15:13
Kagiso II wrote:
07 Nov 2017 12:15
Embarrassingly so... I also thought it was for the hubs...
I recon I will skip this one.
Re: Y61 wheel bearing spanners
Post by Kagiso II » 08 Nov 2017 12:32
nou sien jy .. daar leer ik iets nuuts. Kan jy nou meer. :oldtimer: :oldtimer:
biggles
Full Name: Steven
Nickname: Steve
Home Town: Durbanville
Current 4x4: GUII Patrol 4.8
Has thanked: 13 times
Been thanked: 44 times
Post by biggles » 08 Nov 2017 15:52
Peter Connan wrote:
07 Nov 2017 17:44
biggles wrote:
07 Nov 2017 15:13
Kagiso II wrote:
07 Nov 2017 12:15
:confused: :redface:
I am out.
:layrubber:
Has thanked: 151 times
Been thanked: 246 times
Post by Michael » 09 Nov 2017 20:44
Peter, looks like an actual "hub locking" spanner would sell like hot cakes......... maybe you should make some?
Post by Peter Connan » 10 Nov 2017 05:14
Ja. Can somebody send me the size, and the diameter of the hole around it?
AdrianPowrie
Full Name: Adrian Powrie
Nickname: AdrianPowrie
Current 4x4: 2003 4.8 auto
Nissan 3.0 SE 2x4
Willy's Jeep/toyota...
Been thanked: 7 times
Post by AdrianPowrie » 10 Nov 2017 08:53
I am still in for the bearing spanner and a hub spanner as well for that matter. Pain in the behind having to go to the tool box everytime.
Would be nice to have a smallish tool at hand for the job...
Adrian
2003 4.8
Front bashplate (PC)
Transfer case skid plate (PC)
